Old 10-31-2018, 01:50 AM   #1
birdmanf16
birdmanf16's Avatar
Drives: 2022 Zl1 1lE
Send a message via MSN to birdmanf16 Send a message via Yahoo to birdmanf16
ZL1=SS 1LE suspension?
Does the standard ZL1 have the same suspension and brakes as the SS 1LE? If not, what is the difference and is the SS 1LE a better handling car or the same? Thanks!
2022 Camaro Zl1 1LE, e85, Roto Fab and tune
2020 Colorado ZR2 Dusk edition
2021 Mustang Mach e
birdmanf16 is offline   Reply With Quote
Old 10-31-2018, 02:02 AM   #2
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
1. Both have mag ride, but likely different software for them as the cars are different weights. Not sure about sways.
2. ZL1 has bigger brakes
3. Define better hading. ZL1 puts up faster lap times....but the lighter SS 1LE might feel like it handles better in the turns, while losing ground in the straighter sectors.
ninetres is offline   Reply With Quote
Old 10-31-2018, 08:05 AM   #3
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
The SS 1LE has slightly lateral Gs and is lighter, but it won’t make up for the deficit of power. The SS 1LE is essentially the ZL-1 chassis tune, but there are some differences due to the difference in weight.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 10-31-2018, 09:17 AM   #4
crosive
Drives: 18 zl1
there are different part numbers for quite a bit of the suspension. this either means some of the bushings are different, or the parts are fundamentally different.
the brakes or for sure different, both by numbers and size.
if you were to get zl1 suspension parts, you'd be paying more, and you'd be getting some different parts, but others is a guess. nobody has confirmed if the parts are indeed different or just have different numbers.
crosive is offline   Reply With Quote
Old 10-31-2018, 12:33 PM   #5
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Actually, not true. The part numbers are almost all the same. The part numbers have been listed in another thread on the suspension section.
The bushings, arms, MRC are all the same. The only differences would be to account for the weight difference with sway bar and MRC calibrations.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 10-31-2018, 01:04 PM   #6
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
The Suspension Megathread has all the part number for FE2, FE3 FE4, and FEA suspension components.
Old 10-31-2018, 01:43 PM   #7
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Spring rate?
'18 1SS 1LE Black, PDR
Old 10-31-2018, 02:08 PM   #8
TRZ06
TRZ06's Avatar
Originally Posted by Boost Creep View Post
Spring rate?
Obviously the spring rates will be different. I have no clue what they are though. Anytime you add 200 or so pounds of super charger up front, you have to account for that.
As I stated before, the only differences between the 2 are to account for the weight differences. Most of the components (arms, bushings, ETC.) are the same.
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
Old 10-31-2018, 02:45 PM   #9
crosive
Drives: 18 zl1
I wasn't clear. I see that now that I re-read what I typed. I meant the numbers are different for the suspension over all the different versions (fea, fe4, fe3, etc). I got my information for my kit from that thread and others that have contributed to it, I just congregated it down to my needs and car specifically (2ss a8)
Old 11-03-2018, 05:58 PM   #10
Atlas24601
Drives: 2018 SS 1LE
SS 1LE corners and brakes slightly harder. ZL1 accelerates much faster.
Atlas24601 is offline   Reply With Quote
Old 12-26-2018, 06:57 AM   #11
SaphfireSS
Drives: 2017 Camaro 1LE SS
Same driver 1LE can outperform on autox. Track not so much. From experience. Seen it happen.
SaphfireSS is offline   Reply With Quote
