TireRack
Old 10-28-2018, 04:10 PM   #1
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Car sometimes won’t shift out of 4th
Need your help guys,
This issue started within the last two days. At first I just assumed it was a hiccup, but now it’s happened again and even worse.
Today I was on an open road and did a “spirited” pull while I was in drive (as opposed to paddle shift or sport). Moderately braked to a stop and sat for about 10 seconds then very lightly accelerated from a stop. From the start the car didn’t feel like it was in 1st or 2nd. When I got up to 50 mph, the car aggressively downshifted to 4th and stayed there. I got up to 70ish and the car was approaching 5k on the rpm. I started to coast to give the car a second to shift and nothing. I had to brake for the car to finally shift up to 5th, then 6th.
The car has 25,000 miles on it. 13,000 of which I put on this year. Trans temp was 180 while this was happening.
Any ideas? Gonna start by going through all the electronics first
Overflow is offline   Reply With Quote
Old 10-28-2018, 05:04 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
What happens when you use the paddles? Does the transmission respond to paddle inputs?
Old 10-28-2018, 05:24 PM   #3
Overflow
Overflow's Avatar
Yes. It paddle shifts fine.
Old 10-28-2018, 05:24 PM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Can you check your trans fluid level?
CamaroDreams76 is offline   Reply With Quote
Old 10-28-2018, 06:33 PM   #5
Overflow
Overflow's Avatar
Don’t really have the means to check it. Which is frustrating because that’s a very good idea.
Does it sound like a trans flush?
Old 10-29-2018, 07:02 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Sounds like it needs a Dyno tune, headers and high flow cats with a CAI to fix that trans issue...… Or maybe switch fluids out with some royal purple or something; but I like my first idea better and it results in maybe being able to burn rubber much easier and sounding much more macho while eliminating that annoying AFM …..
christianchevell is offline   Reply With Quote
Old 10-29-2018, 08:34 AM   #7
Overflow
Overflow's Avatar
I'm actually ordering headers for the car on Wednesday. Fixed transmission or not.
Taking the car into the shop at 3pm today. We'll see what they say.
Old 10-29-2018, 08:44 AM   #8
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Judging by the RPMs and speed you noted I would think its actually sticking in 3rd not 4th. I know in my L99 if I was at 5k or so in 3rd I would likely be over 90 mph so just thought I'd mention that in case it matters when getting it diagnosed.
qcman is offline   Reply With Quote
Old 10-29-2018, 09:01 AM   #9
UBB
UBB's Avatar
Drives: 2018 ZL1
tell us more??
UBB is offline   Reply With Quote
Old 10-29-2018, 09:47 AM   #10
Overflow
Overflow's Avatar
You're probably right. I just head it shift through two more gears. So I assumed it was in 4th.
Originally Posted by UBB View Post
tell us more??
Texas Speed 7/8" long tubes.
Also doing a ZL1 front fascia swap with GFX side skirts and rear diffuser. It's gonna be a different animal for Sturgis.
Old 10-29-2018, 10:18 AM   #11
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
New fluid and filter can work miracles sometimes. Only takes a spec of debris to foul up things in the valve body.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 10-29-2018, 10:22 AM   #12
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Hit up Juiced. He gave me a deal on my TSP headers
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 10-29-2018, 11:52 AM   #13
Rock-It Man
A car with 25,000 miles isn't going to be low on transmission fluid unless there's a conspicuous leak, nor does it need a flush, most likely.
Since it paddle shifts OK, it sounds like an electronic or software problem.
Old 10-29-2018, 12:18 PM   #14
Overflow
Overflow's Avatar
It's currently at the shop. Guy said he'd get back to me by 5pm. I'm anxious to see what's going on.
Oh sweet! Will do.
One of my friends through out a software update. Any idea what Chevrolet would charge for a software update?
