Old 10-28-2018, 09:54 AM   #1
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Accessory power tap for 2nd 12V outlet
I don't like the look of the wires coming out of the phone charge adaptor sticking out of the 12V accessory outlet on top of the center console. I'd like to add an additional outlet somewhere unseen under the dash where I can plug in a dual adaptor and run the wires under the console to the sides of the seats where they will be easy to access and can be tucked away when not used. I see on on few posts that the center console can be lifted to tap into the purple wire connected to the existing accessory outlet. Does anyone know if this circuit can be accessed more easily under the dash to avoid the need to pull up the console?
17rsvert is offline   Reply With Quote
Old 11-09-2018, 10:36 AM   #2
17rsvert
17rsvert's Avatar
No one has any experience here to help me out?
Old 11-09-2018, 12:45 PM   #3
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
What about the outlets inside of the center console?
TonyNo is offline   Reply With Quote
Old 11-09-2018, 01:04 PM   #4
17rsvert
17rsvert's Avatar
I have a USB drive with music on one, and the other I use when I want to hook up with android auto. And that leaves nothing for my wife's phone.
Old 11-09-2018, 03:27 PM   #5
MANNAXMAN
MANNAXMAN's Avatar
Have you considered connecting a USB splitter to one of the ports inside the center console?
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 11-09-2018, 04:54 PM   #6
TonyNo
TonyNo's Avatar
You can access the wiring in the center console by just pulling the shifter bezel off. You can also ease running wires by pulling either side of the console "skirts" off.
I connected power there for my forward-camera monitor.
Old 11-09-2018, 07:52 PM   #7
17rsvert
17rsvert's Avatar
Thanks! Anyone know of any previous posts that show the correct way to pull the bezel off?
Old 11-09-2018, 08:26 PM   #8
TonyNo
TonyNo's Avatar
Using a trim tool, pry the bezel from the console around the outside edges. It comes out straight up. I think there were six clips, three on each side. If you have an auto trans, you'll need to shift out of park for easiest access.
Old 11-10-2018, 11:36 AM   #9
17rsvert
17rsvert's Avatar
Thanks TonyKnow
Old 11-10-2018, 01:35 PM   #10
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
See step2 in the .pdf file at the bottom of this post. I used two pieces of duct tape in the vertical section around (in front of) the parking brake button. Using this method it easily pops right out with no tools. The plastic trim tools I had weren't quite optimal for the job and I was worried about damaging the plastic bezel with the tools that I did have handy.
https://www.camaro6.com/forums/showp...7&postcount=14
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 11-10-2018, 03:41 PM   #11
17rsvert
17rsvert's Avatar
Thanks vtirocz, I like that duct tape move. No chance of dents. Any idea how easy it is to get to the accessory power wire with just the bezel removed?
Old 11-10-2018, 03:51 PM   #12
TonyNo
TonyNo's Avatar
It's easy, but you need to get the wires into/out of that area. Pulling one of the side-skirts back is pretty easy, except for the front clips.
Old 11-11-2018, 05:07 PM   #13
TonyNo
TonyNo's Avatar
Follow-Up: Prying the bezel out from the rear end is not a good way to do it. Insert your trim tool between the parking-brake button and the bezel.
Old 05-07-2019, 12:53 PM   #14
Camaro_49
Drives: Camaro
How exactly did you get to the accessory power? I’ve got the bezel pulled off but see no way to get to the accessory power
Camaro_49 is offline   Reply With Quote
