Old 10-26-2018, 08:35 AM   #1
Alex74
Alex74's Avatar
Drives: 2018 NFG SS 1LE
Front splitter replacement / splitter leaking water?!
I cracked the front splitter - I *think* I must have hit a small piece of road debris and put a hairline in it. Don't recall when, but noticed the crack last night.
A search indicates its not too hard to replace the splitter but a couple of questions:
I'm not in a particular rush to replace this side of winter, but suggestions on the best place to source a replacement would be welcome.
Also, for those that have had to replace, did anyone find an alternative to pop-rivets when re-attaching? I read some posts about rubber compression nuts (not sure of the technical term)...??
The really interesting thing is that the small crack in the splitter is leaking!
I'll assume this isn't some kind of front-end ballast, but rain/wash water finding a way in - anyone else come across this?! Thoughts on that welcome!
Cheers,
Alex
Alex74 is offline   Reply With Quote
Old 10-26-2018, 08:56 AM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Not sure about an alternative to rivets, but yeah these absolutely like to hold water. I drilled a few holes in the bottom of mine (one at each end then two more evenly spaced between the first two) to help let the water drain out.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 10-26-2018, 09:40 AM   #3
M.A.K.
Drives: 2017 SS 1LE , 75 Caddy, 15 Cruze
I had a similar experience (racoon) and replaced the stock piece with one from RPI, was a much more reasonable price and made of more durable/ flexible material than the hard plastic stock unit. Looks identical except for being a slightly more matte colour which I prefer and have used it for the season with no issues... would suggest checking them out.
M.A.K. is offline   Reply With Quote
Old 10-26-2018, 10:21 AM   #4
Alex74
Alex74's Avatar
Thanks both -
At the moment its "fixed" with clear gorilla tape and think I'll be drilling a few small holes this weekend.
Will check out the RPI splitter.
Old 10-26-2018, 10:58 AM   #5
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Originally Posted by Alex74 View Post
Thanks both -
If you do get the RPI one I highly recommend wrapping it with PPF, the paint quality isn’t that great on it so my was mutilated after my first track day with it on the car.
IG: @NC_M1SS1LE
Old 10-31-2018, 03:32 PM   #6
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
I got my replacement from ACS composites. solid quality. I saved some money and had it painted locally. I looked for rivet alternatives but found nothing really reasonable.
When I cracked my OEM one, I caught the corner of a curb in a parking lot. made a huge crack and I felt it in the seat. Scared the shit outta me when I jumped out to look at the damage and saw a puddle of water forming. I thought I REALLY nailed it and cracked a radiator or something. Nope. The splitter just likes to collect water.
eimarshall is offline   Reply With Quote
Old 10-31-2018, 04:05 PM   #7
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Wonder if any split from freezing in the winter.
'18 1SS 1LE Black, PDR
Old 10-31-2018, 09:41 PM   #8
Alex74
Alex74's Avatar
I drilled two small holes in the splitter this past weekend - one each end - the amount of water that drained out was really surprising. I'd guess at least a quart.
Old 11-01-2018, 12:59 PM   #9
hms2488485
hms2488485's Avatar
Drives: '17 Camaro SS 1LE
Same for me. I bumped a curb in a parking space and put a small hole in mine, right dead center and I noticed that water was leaking out, so I just left it as is so the water would drain out
hms2488485 is offline   Reply With Quote
Old 12-26-2018, 06:01 AM   #10
SaphfireSS
Drives: 2017 Camaro 1LE SS
Street scene splitter. Looks better, solid piece not hollow, more durable but will still break when hitting dead pig in road. Just FYI. Lol
SaphfireSS is offline   Reply With Quote
