Old 10-25-2018, 08:31 PM   #1
LordKevin
Drives: 2016 Camaro 2ss Red Hot
Does this tire look repairable?
I got a screw in my tire and I took it to a firestone and they put a plug patch in it and the guy said he can’t promise it won’t leak again.Well a couple hours later and it went from 35 psi to 21. He said the screw was at a steep angle. Can you guys give me your thoughts and advice? I just bought this tire about 5 months ago.
https://imgur.com/a/wMjOXL3
LordKevin is offline   Reply With Quote
Old 10-25-2018, 09:39 PM   #2
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
I know the feeling. I just got one of my run flats repaired yesterday. The nail was in the passenger rear tire. Dead center. I called my Chevy dealership to see if they would attempt a repair and they told me GM will not permit them to repair a run flat. New tire or nothing. $345 bucks. The hell with that! I took it to NTB where they plugged and patched it. So far so good. Come spring Though, I’m getting a good regular set of tires. These run flats aren’t worth the aggravation with so much debris on the roadways.
STYLO LT1 is offline   Reply With Quote
Old 10-26-2018, 07:50 AM   #3
TJay74
I would love to be at a dealership and have them say that to me. Goodyear, Michelin and Continental all state a runflat can be repaired once with no issues.
That is nothing more than dealership BS and trying to push selling a new tire.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 10-26-2018, 12:43 PM   #4
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
To me, that looks repairable based on what and where it is. If it was closer to the sidewalls, it'd be more iffy. I think the patch was not done correctly.
torqueaddict is offline   Reply With Quote
Old 10-26-2018, 12:52 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
I had a tire with a screw at an angle. I was going to plug it at home and then get an internal patch later.
But reaming that angled hole cut through so many steel cords that obviously the tire was no longer safe, so I had it replaced immediately.
As for a plug leaking, the tire should be taken off the rim and patched from the inside for a permanent repair. However, I've never experienced a plug leaking that fast, so maybe the tire really does have too much damage for a safe repair.
Places that refuse to repair run flats are concerned that the tire may have been driven too long at zero pressure and structurally damaged. Basically, the purpose of a run flat is to get you safely off the highway and into a tire shop where it can be replaced.
Old 10-26-2018, 03:18 PM   #6
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Yes it can be repaired. Have a patch put on the inside of the tire and it should be good to go. I have had tires repaired this way over the years and had no problems.
Old 10-26-2018, 03:23 PM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
IMO, a place that refuses to do a repair is afraid of Lawsuits!
Old 10-26-2018, 03:40 PM   #8
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
I cant see the picture to do computer access at work not letting me open links but I had a GIANT bolt in my tire, big enough to fit the tip of my pinky in.
this thing leaked to 0 psi within 120 seconds.
I bought new tires but looked at them and was like eh ill throw the new ones on after winter.
I went to autozone, bought a 5.99 plug kit and took TWO plugs and inserted them, cut the slack and drove around for a bit to heat up the tar/silicone coating.
hasn't leaked a psi in two months and 8k miles.
Kise is offline   Reply With Quote
Old 10-27-2018, 07:05 AM   #9
VinnAY
Drives: 18 1SS/1LE
That's a HORRIBLE idea.
Old 10-27-2018, 09:27 AM   #10
MrNoMercy5000
If it's on the inside curve where it transitions to the sidewall most places wont do it.
MrNoMercy5000 is offline   Reply With Quote
Old 10-27-2018, 12:49 PM   #11
LordKevin
Well I ended up getting fix a flat to “supplement” the patch plug and it’s been good since yesterday.
Old 10-27-2018, 06:50 PM   #12
VinnAY
Drives: 18 1SS/1LE
For the time to continue to do the wrong thing here you could have done it correctly. Just demonstrating being stupid isn't what I'd think you would want to be doing here.
Old 10-27-2018, 09:55 PM   #13
Rock-It Man
Tire sealant is also temporary. When you say "patch plug", what do you mean? Was the tire removed and patched from the inside, or not?
While I have driven with conventional plugs before, a leaky plug is a pretty good indication that the damage is too large for the plug.
I hope you take the advice to replace the tire. Be safe.
Old 10-31-2018, 12:48 PM   #14
man0steel
Drives: 2016 2LT vert 2.0 R/S A8
A "patch plug" is just that, a combination of the two. You could think of it as a round regular patch with a tail on it that is pulled thru from the inside (tire removed from wheel). I have used these before without issue, same tire repair rules apply. Only once and not by the sidewall.
man0steel is offline   Reply With Quote
