Old 10-24-2018, 09:13 AM   #1
Slamm06
Drives: 2017 Camaro SS
Driver side door rubbing
Has anyone noticed the driver side door rubbing against the body? I just noticed mine is rubbing at the bottom
Slamm06 is offline   Reply With Quote
Old 10-24-2018, 10:52 AM   #2
tom's2005gto
Drives: 2016 2SS A8 Convertible
yep same spot
tom's2005gto is offline   Reply With Quote
Old 10-24-2018, 03:30 PM   #3
DougCBJ
Drives: 2016 Blue 2SS
The hyper blue i bought used has that exact issue on both the driver side and the passenger side.
DougCBJ is offline   Reply With Quote
Old 10-24-2018, 03:40 PM   #4
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Will check and report back.
torqueaddict is offline   Reply With Quote
Old 10-24-2018, 05:21 PM   #5
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
mine did on the passenger side , dealer wouldn't fix it under warranty , it was $1200 so i put it on my insurance and paid the $100 deductable . there is another thread on this someplace alot of others have the same thing, hopefully your dealer will fix it under warranty.
NYJets12 is offline   Reply With Quote
Old 10-24-2018, 05:36 PM   #6
NYJets12
NYJets12's Avatar
https://www.camaro6.com/forums/showt...t=door+rubbing
i found two there's another one about 4-5 pages long I can't find it don't remember what i searched for 1st time to find it.
Old 10-24-2018, 10:49 PM   #7
torqueaddict
Well I'm happy to report I do not have this issue. Hopefully, it stays that way (~6.6k miles).
What was the dealer's reasoning for not honoring the warranty?
Old 10-25-2018, 01:38 AM   #8
Stewhoppy
Drives: 2016 Camaro SS
same same.........
Stewhoppy is offline   Reply With Quote
Old 10-25-2018, 06:41 AM   #9
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
Just looked this morning and I don't have those spots.
As for warranty, if you can prove that you haven't played with the doors (like if the bolts around the hinges have never been touched and don't have scratches or paint chips on them), maybe you can get it fixed under warranty because it was a misaligned door.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 10-25-2018, 10:59 AM   #10
DougCBJ
just throw some touch up paint on there and move on.
Old 10-25-2018, 03:02 PM   #11
NYJets12
NYJets12's Avatar
They said I had to hit something by the passenger side headlights and the quarter panel got moved back. Even though there was no dents. Or I ran over a big pothole and the tire hit the quarter panel and knocked it back towards the door since the door rubs against the quarter panel when you open the door.
It’s a defect in the car, somewhere in the forum I found where others say the bolts keeping the front fender on are loose.
Can’t find it I forgot what words I used when I searched it the first time.
Old 10-25-2018, 03:19 PM   #12
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
I also have a small spot like that inside the driver's side door. I think it's from closing the door, which must compress the seal enough to allow metal to metal contact. One of these days I'll touch it up, and put a little protector pad like for a drawer in that spot.
trohde78 is offline   Reply With Quote
Old 10-25-2018, 08:07 PM   #13
Slamm06
Thanks all for the replies, I will follow up with the dealer
Old 10-27-2018, 03:28 PM   #14
Keifer
Summit White 2SS
Keifer's Avatar
Drives: 2017 Summit White 2SS, 2018 Tahoe
There is a bulletin that recently came out for this issue. Have your dealership look at
18-NA-276 Paint Wear Mark or Chip at Corner of Rocker Panel Molding from Door Over-slam Hem Seal Contact
It is a procedure for doing a “partial paint repair” (touch up) of the affected area, and then applying a small piece of clear mylar tape to keep the door and rocker from contacting in that spot.
It is not an alignment issue with the door, so adjusting the doors will not resolve the concern.
____________________
Keifer is offline   Reply With Quote
