Old 10-23-2018, 12:04 PM   #1
TheAbyss
Drives: 2017 SS
Borla mid pipe
I have the Borla Atak axleback, and thinking of getting the Borla midpipe/xpipe (part # 60607). I am trying to install it through my dealership except they are saying that it takes out the AFM valves which means I have to tune the car, which could void warranty.
I thought the MANUAL SS don't have AFM valves? Will this part risk voiding warranty?
Second, for those who have this part, how does the car sound? are there more crackles and pops?
TheAbyss is offline   Reply With Quote
Old 10-23-2018, 12:43 PM   #2
Mighunter
Drives: 2017 Summit White 2SS
60607 eliminates the AFM valves. 60610 has the AFM valves. I also have the Atak axle back and if i were to add the mid pipes i would do the 60610
Mighunter is offline   Reply With Quote
Old 10-23-2018, 12:55 PM   #3
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Manual has no AFM. GET THE 60606.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 10-23-2018, 12:58 PM   #4
trohde78
trohde78's Avatar
Drives: '17 Red Hot 2SS 6MT
+1
trohde78 is offline   Reply With Quote
Old 10-23-2018, 01:28 PM   #5
18ss376
Drives: Camaro
You started at the wrong end, headers put out the most h.p., a mid or x-pipe maybe 5h.p. & an axle back does nothing for h.p. especially for the A8 cars.
18ss376 is offline   Reply With Quote
Old 10-23-2018, 02:41 PM   #6
TheAbyss
Drives: 2017 SS
I'm totally with you, I would have loved to do that but I would like my warranty for a year or two more!
Old 10-23-2018, 02:43 PM   #7
TheAbyss
Drives: 2017 SS
Thank you!
When I contacted Borla they said 60607. For my manual car with the axleback already installed. Do you know of the difference?
But most importantly how is the sound been for you? Are you satisfied with it?
Old 10-23-2018, 02:56 PM   #8
trohde78
trohde78's Avatar
The 60607 is for connecting to headers, the 60606 has the flanges to connect to the stock primary cats. You can tell if you look closely at the pictures of each version.
Either works with your axle-back, it's the other end that's different. :-)
Old 10-23-2018, 03:49 PM   #9
TheAbyss
Drives: 2017 SS
That clears it up thank you very much
Old 10-23-2018, 11:42 PM   #10
Chris C 1SS 1LE
Drives: 2017 1LE
I am getting the ATAK NPP. chose to do intone step At a time. I haven't put fuse back in. Looked for it today and it's not where I Rember putting it.
Check wheelwell dot com
Old 10-24-2018, 09:31 PM   #11
AdmAnt13
AdmAnt13's Avatar
Drives: '16 Red Hot 2SS M6 NPP
60606 with Atak is what I have. No CEL’s on a manual
'16 2SS, M6, Borla Atak
AdmAnt13 is offline   Reply With Quote
Old 10-28-2018, 09:30 PM   #12
Chris C 1SS 1LE
Drives: 2017 1LE
Lightbulb
NPP? Now I have zero drone-- and drone not abide deal but is the ATAK too much in your experience? On the gas what I have now is pretty awesome yet quiet when not. Thanks for your feedback
Old 10-28-2018, 09:47 PM   #13
AdmAnt13
AdmAnt13's Avatar
The BORLA Atak NPP is loud. No joke. However cruising around there is no drone and it’s as quiet as the stock exhaust in 5th or 6th gear.
It’s when you get on it that it’s loud inside and out.
With that said, even my wife doesn’t complain when in the car.
Stealth mode on the Atak is like NPP on track. So you always have that option if need be. I never experienced the 60606 with the stock NPP so I can’t compare to that, but if you want it loud with good tone, Atak is the way to go.
