Old 10-23-2018, 12:36 AM   #1
Drsagacity
Drsagacity's Avatar
Trunk won’t open
Car threw a nice little trick at me a few days ago. The truck clicks when I use the key fob or when I push the button on the door...but it will not unlock/unlatch.
I messed with it pushing down pretty hard...nothing. I only found out because I went to take the top down and got the message that the divider is not attached...so, I popped the trunk to fix it...except it didn’t work.
I assume the only option is to remove the back seat and go in to use the emergency latch in the trunk. Of course that will really suck with the top up.
Any other options?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 10-23-2018, 12:50 AM   #2
ChickenPoop
Drives: 2019 Plum Crazy Scat Pack Charger
Thnk you are pretty well stuck on that.
ChickenPoop is offline   Reply With Quote
Old 10-23-2018, 06:33 AM   #3
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Well, that’s a bummer. If you take the seat out, what you’ll run into is all of the electronic components for the top. It’s held in place with rigid styrofoam.
I think you can get a better idea of what you’re in for by searching the stereo upgrade section for a convertible. I could have sworn I saw a White ZL1 torn apart.
Old 10-23-2018, 06:39 AM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Need you to crawl through the back seat, dear... yep just like that.
I assume the only option is to remove the back seat and go in to use the emergency latch in the trunk. Of course that will really suck with the top up. Any other options?
I'd tell the wife to put on a pair of short-shorts and come help me fix the Camaro in the garage...
Old 10-23-2018, 07:11 AM   #5
Chutzpah
Chutzpah's Avatar
https://www.camaro6.com/forums/showt...tible+speakers
Old 10-23-2018, 07:30 AM   #6
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
There is a keyhole by the back seats to manually unlatch the trunk. They even give you a plastic 'wrench' to give you more leverage on the key. Check the manual.
17rsvert is offline   Reply With Quote
Old 10-23-2018, 07:45 AM   #7
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
Happened to me twice a few months ago. I pushed down on the trunk and then used the door panel trunk button to pop it again. That resolved it. Sounds like you've already pushed down on it. Try again and follow with the door panel trunk release button instead of the touchpad or keyfob.
Old 10-23-2018, 05:57 PM   #8
Drsagacity
Drsagacity's Avatar
I used the manual unlatch behind the driver side back seat. It's right at the top so you can just pull the seat and insert the key.
Closed the trunk and stuck again. Good news is, I can get stuff out and get my top working, but will need to go to dealership for the fix.
TBD performance
Old 10-24-2018, 04:58 AM   #9
Driski
Drives: 2016 Camaro Convertible 2SS
locked myself out the first year I put the car up for the winter and had to use the manual entry but have not had this happen to me YET! Please let us know what the dealer says.
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
Old 10-24-2018, 08:51 AM   #10
phd1026
phd1026's Avatar
Drives: 2022 2SS Vert in Wild Cherry Tint
Same thing here. Used keyhole behind driver rear seat to open.
phd1026 is offline   Reply With Quote
Old 10-25-2018, 08:16 AM   #11
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
driven2exceSS is offline   Reply With Quote
Old 10-25-2018, 09:00 AM   #12
Drsagacity
Drsagacity's Avatar
Originally Posted by driven2exceSS View Post
I did let her know that was the recommendation from the forum, so we are going to give that a try tomorrow for date night. . .we are going to work on the car together.
TBD performance
Old 10-25-2018, 01:36 PM   #13
driven2exceSS
(could'nt resist putting this emoji to use)
Old 10-28-2018, 08:09 PM   #14
Drsagacity
Drsagacity's Avatar
I will take the car to the dealership soon so that I can have them check it. I was kind of hoping after I opened it the problem would go away...no luck.
TBD performance
