Old 10-22-2018, 07:40 PM   #1
grampa_ss
grampa_ss's Avatar
Help: HP Tuners MPVI2 with which gauge(s)?
I've been searching and can't really find an answer. My question:
I'm buying HP Tuners MPVI2 (and an AEM-X series AFR w/pass thru OBD2 cable) for datalogging. I understand how this works using the AEM pass thru cable and plugging the MPVI2 in that. But...
my question...
how can I datalog at the track and also see IATs on another gauge at the same time?
Can VCM scanner be setup to show some gauges or display IATs (while data logging) ?
Thanks,
Old 11-01-2018, 03:00 PM   #2
Nino8309
Drives: 2018 Summit white 2SS 1LE
Yes you can set it up to display whatever you want while logging. If you have an OBD2 gauge that reads IAT im sure you could just buy another pass thru OBD cable and plug all of them in at the same time.
Nino8309 is offline   Reply With Quote
Old 11-06-2018, 09:34 AM   #3
TJay74
Yes, the scanner can show all sorts of data while logging. I have a section that shows what the sensor is seeing, a gauge section that shows the highest recorded amount and then the line graph and a spreadsheet all at the same time.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 11-17-2018, 01:28 PM   #4
oldman
Drives: SS 6 speed of course
my question is there any wideband that puts lambda values into the ODBII bus so I can data log, I run 93 and e85 so a/f is useless to me.
Old 11-17-2018, 01:30 PM   #5
oldman
my question...
Thanks,
I'm like you but I want to record lambda values and this MPVI2, thing is suppose to have an external cable to get other input(s) cable due out next month over the last 8 months so...
Old 11-17-2018, 09:00 PM   #6
teesee150
Drives: Camaro
Welcome to hptuners, promise features for years, then end up never releasing. Been doing this since the original ls1 days
teesee150 is offline   Reply With Quote
Old 01-21-2019, 06:00 PM   #7
Gen5&Beyond
Gen5&Beyond's Avatar
Drives: 2016 2ss Camaro
Open VCM Scanner. In the left column you should see your wb eq Raitio. Right click on it go over to units and select lambda.
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP
Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118
Gen5&Beyond is offline   Reply With Quote
Old 01-22-2019, 01:19 PM   #8
JANNETTYRACING
JANNETTYRACING's Avatar
Pro set available now through JRE or direct from HPtuners.
https://www.hptuners.com/mpvi2/
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-31-2019, 07:37 AM   #9
DorkMissile
DorkMissile's Avatar
Drives: DZ
FYI - I have a vent mounted dual gauge pod with a AEM X-Series OBD2 data stream that can be setup to monitor any PID on the CAN bus, and have a AEM X-Series OBD2 Wideband that is integrated into Hp tuners to datalog the wideband without the Pro option
The standard MPIV2 can Datalog all PIDs on the car as standard, the Pro option allows Datalog without the computer being linked.
DorkMissile is offline   Reply With Quote
Old 01-31-2019, 08:22 AM   #10
JANNETTYRACING
The Pro option allows you to log Any 0-5 volt analog sensor which all other AFR gauges put out beside the AEM X series Can buss.
Ted.
Old 01-31-2019, 09:19 AM   #11
grampa_ss
grampa_ss's Avatar
This is what I see, so i'm still a little confused.
1. connect the aem wideband w/passthru obd2 to cars obd2 port
2. connect the aem data stream gauge to the aem passthru obd2 connection.
that's where obd2 is terminated.
question is how do I connect my MPVI2 obd2 in order to datalog? there's no open obd2 ports anymore.
Do I need to disconnect the aem data stream gauge which would make the obd2 port available?
Old 01-31-2019, 09:21 AM   #12
JANNETTYRACING
Do I need to disconnect the aem data stream gauge which leaves the port open again?
Yes, it is best to disconnect any OBDII connections other than HPtuners when reading or programming but can be connected during data logging.
Ted.
Old 01-31-2019, 09:30 AM   #13
grampa_ss
grampa_ss's Avatar
Thank you for the quick response.
