Old 10-22-2018, 02:57 PM   #1
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
Creaking/knocking noise - passenger rear
Has anyone else experienced a creaking/knocking sound from the passenger rear area?
just started happening about two weeks ago, car as 25k miles.
typically it makes the sound when the car shifts momentum upon acceleration or around turns.
has been annoying the hell out of me.
not sure if this is in relation but I occasionally have a rattling sound also around the rear window.
I thought the creaking could have been maybe something in the trunk or the seatbelt but neither seemed to be the case.
I thought the rattling could've been loose components in the back seat latch or the rear speaker/sub but those were also ruled out.
any info helps!
Kise is offline   Reply With Quote
Old 10-22-2018, 03:11 PM   #2
Chevy1American
Drives: 2SS
Yes been having a random creaking noise started a couple of weeks ago as you say passenger side rear car has done 3000 miles would love to know what’s causing it
Chevy1American is offline   Reply With Quote
Old 10-22-2018, 10:18 PM   #3
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
Might be related to the rear passenger side clunk many of us have also experienced.
STYLO LT1 is offline   Reply With Quote
Old 10-23-2018, 12:42 AM   #4
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
No such issue, but I only have 6500 miles. Could be a loose suspension part. Take it to the dealer and have them check it over. If it's easy to hear, have a mechanic ride with you.
torqueaddict is offline   Reply With Quote
Old 10-23-2018, 03:16 AM   #5
soldes
Drives: car
Probably a long shot but the styrofoam like tray in the trunk does make a creaking noise, especially in warmer weather. I do hear it over the radio.
soldes is offline   Reply With Quote
Old 10-23-2018, 09:13 AM   #6
Fixa
Drives: 2018 1LE
Passenger side rear squeak
Solved a rear passenger side squeak by lubricating the top mount of the front passenger seatbelt with spray lubricant. Was a high pitched squeaking sound now its gone.
Fixa is offline   Reply With Quote
Old 10-23-2018, 03:28 PM   #7
Paro
Drives: 2016 Hyper Blue 2SS A8
I have had the clunk for a year or so... 20,000 miles on car now. I believe it has to do with the CV axle splines and wheel hub interface. Too much play in something rotational. It's not the suspension.
It, very slowly, will get move prevalent and is annoying as hell if you keep listening for it.
A new thrust washer may fix it, or maybe CV axles and wheel bearings.??
Paro is offline   Reply With Quote
Old 10-23-2018, 05:19 PM   #8
Baddawg53
Drives: 17 hyper blue 2SS M6
I’ve recently had some kind of a body creak pop up, mostly on take offs but it’s definitely progressed and gotten louder. Gonna check the rear suspension bushings myself, highly doubt the dealer would be willing to put any real effort into a noise like that. It’s annoying, and frustrating to spend 50k on a car that creaks...
Baddawg53 is offline   Reply With Quote
Old 10-24-2018, 02:02 AM   #9
soldes
Drives: car
some more info here : https://www.camaro6.com/forums/showt...t=creak&page=4
It goes as far as missing spotwelds on the body panels.
Hope it helps,
Nick
Old 10-25-2018, 04:23 PM   #10
Kise
Kise's Avatar
its not that easy in my area, the rear end groan took 12 different trips and ride alongs to have them attempt ONE flush. GM was involved as my rear end grinds now and they still didn't do anything but offer a warranty.
ill be trying a new dealer and hope they can get this squared away.
Old 10-25-2018, 04:25 PM   #11
Kise
Kise's Avatar
couldn't have said it any better.
Old 09-25-2021, 09:09 PM   #12
OniCamaro
Drives: Camaro V6 2017
OP, did you ever figure this out? I feel like I have the same Creaking/ticking kind of noise from the rear trunk area accompanied by an occasional rattling sound near rear window. Drives me crazy that it's so hard to have this car stop making all kinds of annoying noises at once, something or the other keeps popping up, so frustrating...
OniCamaro is offline   Reply With Quote
Old 09-26-2021, 08:56 AM   #13
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I’m surprised I didn’t know this was a thing, I have a noise similar to rattling at my rear passenger. Noise increases with the back seats down. Thought maybe a clip is loose and is rattling in its hole
2016 1LT v6
- Totaled
Happiness: Infinite
