Old 10-20-2018, 03:38 PM   #1
70chevelleSS
70chevelleSS's Avatar
Drives: 2017 Camaro SS 1970 chevelle SS
Weird noise from rear wheel
https://youtu.be/kFeWTn6nQpc
Anyone know what this noise is? It only happens when I go off pavement onto my bumpy gravel driveway. Seems to be coming from the drivers rear wheel
70chevelleSS is offline   Reply With Quote
Old 10-20-2018, 03:42 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
This is common on our cars. To fix:
1. remove the wheel.
2. clean the mating hub and wheel surfaces really well with a wire brush and wipe clean with windex, brake cleaner, or alcohol, etc.
3. apply a THIN layer of white lithium grease.
4. remount the wheel and torque to spec: 140 ft-lbs.
Old 10-20-2018, 11:48 PM   #3
70chevelleSS
Will do. Thanks!
Old 10-21-2018, 10:54 AM   #4
Lerch98
Lerch98's Avatar
Drives: 2017 2SS black on black on black.
Is that the wheel flexing and rubbing on the hub?
Lerch98 is offline   Reply With Quote
Old 10-21-2018, 10:59 AM   #5
70chevelleSS
It would appear so. I did the above on all four wheels, seems to have fixed it.
2017 camaro SS A8
FBO With all porting and tuning done by PRAY
