Old 10-17-2018, 06:32 PM   #1
BARNESGN
Drives: Sold-G8 GT H/C/I
Cam swap Always pull engine?
Just wondering if pulling the engine is the way to go on a cam swap.
What are some going rates for this kind of service.
BARNESGN is offline   Reply With Quote
Old 10-17-2018, 06:47 PM   #2
oldman
Drives: SS 6 speed of course
I pulled the cam out from the front... I did drop the pan, only because: If you pin the chain you won't have enough room to rotate the chain off the back of the timing gear. So DON'T PIN THE CHAIN TENSIONER. I did create a guide to make sure it went back to TDC here is a pic. You can see the alan wrench I used to pin the tensioner on the left.
Name:  chain guide.jpg
I would say a good mechanic would take dunno 12 hours? The heads have to come off to change the lifters so port them at the same time. I took like 6 days of part time work, but really had no issues. It really was about as easy as a LS1 Camaro.
Old 10-17-2018, 07:20 PM   #3
Wheat_Fed_SS
Wheat_Fed_SS's Avatar
Drives: 2016 Camaro SS
My guy didn’t pull the engine and I think it was 14 hours... it was his first 6th gen he’s done so they took a little extra time.
Wheat_Fed_SS is offline   Reply With Quote
Old 10-17-2018, 08:40 PM   #4
Whocares05050
Drives: 2018 Camaro SS 1LE
12-14 hours? Fuuuuuuuuuuuuuuuu
Whocares05050 is offline   Reply With Quote
Old 10-18-2018, 09:30 AM   #5
Matt@Tick
Matt@Tick's Avatar
Drives: All GM Performance
I didn't pull the ones I've done.
Matt@Tick is offline   Reply With Quote
Old 10-18-2018, 09:44 AM   #6
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
i didnt pull the engine
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 10-19-2018, 12:37 PM   #7
GuywithL86
Drives: Black
12 hours with a good mechanic? Like one with a lift that does it for a living? Damn, no wonder everybody pulls the motor out.
GuywithL86 is offline   Reply With Quote
Old 10-20-2018, 08:58 AM   #8
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
Pulling the engine isn’t necessary. But I’ve heard the pan needs to be dropped. Is this true? I’ve done a few LS cam swaps and they were a breeze. Is the LT engines much different?
02fbody35th is offline   Reply With Quote
Old 10-20-2018, 01:10 PM   #9
mariojmoe
Drives: C7 Z06 manual, 18 Zl1 manual, etc
Motor out absolutely not necessary. Oil pan removed yes sir. Is cam swaps are much easier than lt's
mariojmoe is offline   Reply With Quote
Old 10-20-2018, 01:51 PM   #10
oldman
I did drop the pan, but I'm told that if you don't pin the chain tensioner you can rotate the chain off the cam gear. So I at least 99.5% sure the pan does NOT have to come off, just don't pin the tensioner, see my pic above.
