Old 10-14-2018, 02:55 PM   #1
Velasco1LE
@1LE_BRUH
Drives: 2018 1SS 1LE - WHITE
2018 1SS 1LE / Kooks 1 7/8th LT Headers CLICKING
Good Morning,
I had longtube headers installed in my car not too long ago and ever since I got them, I’ve noticed a ticking sound coming from the engine bay inside the car at low RPM’s when driving. It’s really annoying and just doesn’t sound right. Anyone know what this might be from?
2018 1SS 1LE
Velasco1LE is offline   Reply With Quote
Old 10-14-2018, 03:00 PM   #2
01cbr929
Drives: Which one?
I had the same noise with long tubes on my C6 years back. Never changed, just a little more noise.
01cbr929 is offline   Reply With Quote
Old 10-14-2018, 05:11 PM   #3
NinoSS
Drives: 2SS/RS CGM LS3
I think the thinner walls of the LT's vs the OEM manifolds allows you to hear the valve train more. I did LT's in my 2007 Jeep SRT8 and it drove me crazy. My 2010 SS had a noisy valve train after LT's as well... My .02...
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 10-14-2018, 07:50 PM   #4
Ebbsnflows
Drives: 2018 Camaro ZL1-1LE
Does the tick come from one side or both? If only from one side, have you checked for exhaust leaks? If it's an exhaust leak, at idle, have someone take 2 wet rags and briefly cover your exhaust tips. Covering the tips will cause back pressure and will make the exhaust leak much more noticeable/audible in the engine bay. Only cover the tips for 3-4 seconds at a time (will stall engine otherwise).
A lose spark plug can cause ticking as well (but you would likely get CEL).
If you hear it from both sides, then I think NinoSS is probably correct - it's just the nature of longtubes and their thin sidewalls, exaggerating/amplifying exhaust pulse/pings.
2018 Camaro ZL1/1LE
Ebbsnflows is offline   Reply With Quote
Old 10-14-2018, 08:30 PM   #5
NinoSS
In my SRT8, the ticking was maddening. So much so that I had tune time performance (blow smoke up my butt) They put smoke in my tail pipe to see if there was a leak by the heads. We saw nothing.
Old 10-14-2018, 08:51 PM   #6
Whocares05050
Drives: 2018 Camaro SS 1LE
Normal
Whocares05050 is offline   Reply With Quote
Old 10-14-2018, 10:13 PM   #7
NinoSS
After my 2010 SS cam install, my car sounded like a sewing machine...
