Old 10-11-2018, 09:17 PM   #1
samsumon
Drives: 4 wheels
absolute best way to POLISH a window clean?
I have gunk from parking stickers that wont come off at all.. I even tried smoe razor blades.
What's the absolute best way to get my windows to crystal clear again?
Thanks
samsumon is offline   Reply With Quote
Old 10-12-2018, 07:39 AM   #2
68Vette
Drives: 1SS Hyper Blue Metallic, MRC, NPP
Thanks
For the sticky residue left by the stickers you can use Zippo lighter fluid or goo gone, as far as the rest of the windshield try wiping it down with Isopropyl Alcohol and a good waffle towel.
68Vette is offline   Reply With Quote
Old 10-12-2018, 09:16 AM   #3
GP86
GP86's Avatar
Drives: 2017 2SS
Try the Ultimate Cloth. http://a.co/d/3khkxjx
This is superior to any "microfiber cloth" on glass. I use them on my windows, but mostly for my eye glasses. You need to get the cloth wet, then wring the hell out of it to get as much water out as possible. It will remove whatever is on the glass. You may try to use it with a bit of lighter fluid if straight water doesn't work.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
GP86 is offline   Reply With Quote
Old 10-12-2018, 10:00 AM   #4
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
Try WD40. Seems to work on most goo.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 10-12-2018, 10:37 AM   #5
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
Tar-X works for everything and I don't smell like my zippo lighter when I am done.
warren3537 is offline   Reply With Quote
Old 10-12-2018, 02:12 PM   #6
srcstc
Windex and a razor usually works on any sticker residue.
srcstc is offline   Reply With Quote
Old 10-12-2018, 02:27 PM   #7
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
A trick I use to take off sticker crud is using plastic wrap to encase the crud in goo gone.
So you basically get some plastic wrap that you use in the kitchen, some painter's tape and goo gone. Use the plastic wrap and tape to make a pocket around the crud with the top edge open. Shoot the goo gone into the top edge so it fills the pocket then seal that edge with tape. Let it sit for an hour, then pull it off and wipe it off.
All you're basically doing is letting the goo gone soak into the crud to loosen it off rather than letting the goo gone evaporate away. Same thing as when you soak a pot in dish soap before you scrub it.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 10-12-2018, 07:45 PM   #8
KirkH
I use razor blades and glass cleaner. You just have to keep at it. You can try glass polish with a glass polishing disk on a drill or a dual action polisher, but I usually use the polish after I have gotten the glue residue off.
Old 10-13-2018, 09:12 AM   #9
Sheriff Justice
If your not 1st your last
Sheriff Justice's Avatar
Drives: 2014 Camaro 2SS / RS
Quick & easy try Mr. Clean Magic Eraser pad (both outside and inside window useful).
I also have glass polish liquid with a white polish pad for my Flex D/A that I use every fall and spring to remove all the grime and prep the glass.
2014 Camaro 2SS / RS ~ Blue Ray Metallic w/ Silver Rally Stripes ~ V8 6.2L ~ Blue & Black 2-tone leather interior accent trim package ~ Custom decals from Emblem Pros
Sheriff Justice is offline   Reply With Quote
Old 10-13-2018, 04:11 PM   #10
Ox45
Hillbilly Highness
Drives: 2001 S10, 2022 LT1 Vert
This. Worked for me 100%. I dunno why, but it does!
Ox.
Ox45 is offline   Reply With Quote
Old 10-14-2018, 10:41 AM   #11
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Ox.
Because it's a solvent! I use Kerosene all over the car, yes even the paint. I've done many car shows and would admire the paint on some of these cars and what did they use to clean them...Kerosene! Great for removing sticker residue and tar and before a clay bar. I clean the area afterwards before applying another product.
1hprush is offline   Reply With Quote
