Old 10-09-2018, 08:20 PM   #1
GAOLDGUY
GAOLDGUY's Avatar
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE
Finally An All Season Tire That Fits
I finally found an all season tire that I think I can run on our wheels during the winter in Atlanta. Bridgestone has Potenza RE980AS in the following sizes; 285/35/20, 295/30/20, and 305/30/20. I was thinking of using the 295/30/20 on the front. It's only 10mm larger. Can anyone provide feedback on fit? I can't imagine that 5mm each way would make a difference but I thought I would post to be sure. I think I have seen others running 285/35/20 on the front so the height should be fine. Bridgestone does not have rim width recommendations on their website for this size yet. I assume 295/30/20 is good on a 10 inch rim. Anyone have any feedback on that?
GAOLDGUY is offline   Reply With Quote
Old 10-10-2018, 08:13 AM   #2
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
Awesome just checked it out.
It gets priced out to $951.96
I was going to do the BFgoodrich comp 2 A/S but i guess there no longer supported through tirerack..damn. The price OTD was $801 when i kept checking. Size would've been 275/30/20 and 295/30/20 i believe.
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
Reddy1LE is offline   Reply With Quote
Old 10-10-2018, 08:54 AM   #3
Idyll
lost between two shores
Idyll's Avatar
Drives: 2020 SS 1LE
Isn't your average winter temps in the 50's?
Idyll is offline   Reply With Quote
Old 10-10-2018, 09:21 AM   #4
1LExtreme
Drives: 2018 Camaro 1LE
I just went through the process of trying to find an all seaosn tire and first I tried the bf goodrich g force comp 2 a/s 285/35/20. They did not fit in the front the tire was rubbing everywhere. I am pretty sure you will get same result with every 285/35/20 tire because there is minimal clearance.
The only tire I was able to find that fits is the continental dsw 06 285/30/20, its a little stretched on the rear wheel but it works.
1LExtreme is offline   Reply With Quote
Old 10-10-2018, 09:57 AM   #5
GAOLDGUY
GAOLDGUY's Avatar
For sizes, I wanted to run the 295/30/20 on the front and the 305/30/20 on the back and I was trying to find out if there would be clearance issues on the 295. That is only 10mm which would just be 5mm on each side. I know clearance is tight with the magride and wanted to see if anyone had experience with that size on the front.
Old 10-10-2018, 09:58 AM   #6
GAOLDGUY
GAOLDGUY's Avatar
Unfortunately we get some strange dips in temps that get pretty cold. It usually happens in Dec and Jan but I want to be able to daily drive with no restrictions. Once or twice a year we will get a light dusting of snow but nothing that really sticks.
Old 10-10-2018, 10:01 AM   #7
GAOLDGUY
GAOLDGUY's Avatar
The reason I posted is these Potenzas offer a 295/30/20 and a 305/30/20. I think these sizes are brand new.
Old 10-10-2018, 10:08 AM   #8
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Absolutely insane if you ask me...
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 10-10-2018, 10:55 AM   #9
RKeeton
Drives: 2013 BMW M3
I installed the Bridgestone RE-71R in the 295/30/20 sizes on my stock wheels. The only problem was getting the tires to seat on the front 10" wheels. It took the tech quite a while. There is no rubbing at 2.5 degrees negative camber. The rears were easy to mount and no rubbing at 1.5 degrees negative camber. Hope this helps.
RKeeton is offline   Reply With Quote
Old 10-12-2018, 10:54 AM   #10
AZ_1LE
Drives: 2019 ZL1 1LE
At least he's not keeping them on year-round. At least, I hope he doesn't.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 10-12-2018, 11:23 AM   #11
MarkC
MarkC's Avatar
Drives: 2018 HBM 2SS/1LE
Why? What's wrong with running ALL SEASON tires ALL YEAR
Bridgestone also makes a Potenza RE970AS in stock front size.
Add the RE980AS on the back in stock size and enjoy the car year round in any weather
I went with RE970 in the front and S0001 in the back, and yes that will be for the entire year.
2017 Admiral Blue Corvette Grand Sport Convertible
MarkC is offline   Reply With Quote
Old 10-12-2018, 04:13 PM   #12
Atlas24601
Drives: 2018 SS 1LE
Prepare for "because 1LE" responses.
Atlas24601 is offline   Reply With Quote
Old 10-12-2018, 07:00 PM   #13
AZ_1LE
So basically you paid $7k extra over an SS for the vinyl wrapped hood, wheels, and suede steering wheel and shift knob? Interesting.
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 10-12-2018, 07:39 PM   #14
Goldfish
Drives: 18 2SS 1LE
Goldfish is offline   Reply With Quote
