10-08-2018, 10:11 AM | #1 |
Drives: 2017 Camaro 1SS A8 Join Date: Sep 2018
Custom Painted MSD Atomic Airforce Manifold
Check this out! I spent the day yesterday porting the manifold, painting it to match the exterior of the Camaro, painted the lettering black and then bye bye heat soak! Thanks to Heat shield products we were able to make sure the temp will stay down. You can do anything you put your mind to. Shout out to MSD and Katech for your awesome parts!
2017 1SS Bright Yellow A8
Speed Engineering 1 7/8 headers, MBRP 3in Dual Cat Back Quad Tips Race Version, Katech 103mm TB, K&N CAI, MSD Atomic Airforce Manifold. |
10-08-2018, 10:12 AM | #2 |
Who Needs to KNOW?
It's definitely yellow. Krylon touch ftw.
ing for grip.
10-08-2018, 10:17 AM | #3 |
Thanks, had my local paint shop mix the paint for me.
10-08-2018, 10:25 AM | #4 |
Drives: SS 6 speed of course Join Date: Jan 2016
looks great....
10-08-2018, 03:49 PM | #5 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Do you have a link to the heat shielding you used?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
10-08-2018, 04:03 PM | #6 |
Here is the link. https://www.autoanything.com/exhaust...A7245A0A0.aspx Significantly reduces the amount of heat transfer from the top of the engine to the intake manifold, helping to reduce air-intake temperatures and increase horsepower. Lower air-intake manifold temperatures create a denser air/fuel mixture, creating more power. I bought the 11x23 piece and still have some left over.
10-08-2018, 05:47 PM | #7 |
Really nice work!!! Paint work came out great and heat shielding was a nice touch.
10-08-2018, 06:11 PM | #8 |
Thank you very much. Going to install tomorrow.
10-08-2018, 08:32 PM | #9 |
Drives: 2016 2ss Join Date: Jan 2017
Seen your from sandusky, did you port your msd yourself or have someone donit?
10-09-2018, 05:36 AM | #10 |
Yes I am from Sandusky. I did all the porting work myself.
Thanks for asking Joe
10-09-2018, 09:20 AM | #11 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
wonder if theres test of that heat shielding... looks interesting
Florida High Performance: H/C Whipple LME 377 900WHP
10-09-2018, 12:45 PM | #12 |
There has been testing I researched it myself.
10-09-2018, 05:21 PM | #13 |
Drives: 2016 ss camaro Join Date: Jan 2018
Just ordered the insulation tape, thanks for posting the part #.
10-09-2018, 07:28 PM | #14 |
No problem. I installed the Manifold today and had know problem even with the heat shield being on.
Tags |
heat shield, katech, msd atomic airforce manifold |
