Old 10-06-2018, 01:18 PM   #1
Wheat_Fed_SS
Wheat_Fed_SS's Avatar
Drives: 2016 Camaro SS
Question Anyone know how to fix this exhaust problem?
Around the 23 second mark you will hear a rappid popping noise that also happens when I go from 3rd to 4th gear.. it happens every cold start as well just at the beginning.. it’s annoying to say the least.. I have a BTR stage 1 cam, kooks LT with off road pipes and muffler delete.. zero cats.. stock x pipe and the thebpinch pipes are still present.. all the shops are claiming it’s because I don’t have a muffler but I’m not buying that.. before the headers and cam when I took the mufflers off... I love the sound of the car but like I said driving it causes that annoying rapid popping sound...
https://youtu.be/HSgvALcG9GA
Please help lol...
Wheat_Fed_SS is offline   Reply With Quote
Old 10-06-2018, 01:40 PM   #2
Drsagacity
Drsagacity's Avatar
Please help lol...
The video says, “untuned”. Is that accurate?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 10-06-2018, 05:07 PM   #3
Wheat_Fed_SS
Yea then it was untuned but it’s still makeong the noise now that it is... this was the only video that I have with it because I’m just now getting frustrated with it... after asking around everyone wants to say it’s becaues I don’t have a muffler and try to quote me 1800 for a full exhaust system..
Old 10-06-2018, 08:19 PM   #4
Drsagacity
Drsagacity's Avatar
You said that it happens in a specific gear, is it at a consistent RPM? It almost sounds like the noise I don't like on mine just above 1500 RPM's. I control it by either throttle control or by manual shifting.
TBD performance
Old 10-06-2018, 10:39 PM   #5
Wheat_Fed_SS
It happens often from 3rd to 4th gear and that’s when it’s at its worst.. other than that it’s bareable.. and I can control it with going super easy on the throttle.. haven’t tried the manual shift yet.. it just happens at certain frequencies... and like I said before I’m not sold on me not having a muffler is what’s causing it.. thought it was maybe the extra pressure going thru the pinch pipes causing that terrible popping noise..
Are you running a similar set up?? If not what are you running that’s giving you the similar noise?
Old 10-06-2018, 11:14 PM   #6
Drsagacity
Drsagacity's Avatar
Kooks headers to race pipes (no cats).
TBD performance
Old 10-07-2018, 10:27 AM   #7
Wheat_Fed_SS
So you are still rocking the muffler?
Old 10-09-2018, 11:04 AM   #8
Wheat_Fed_SS
Well deleting the crunched pipes didn’t work.. kinda made it not as loud when it happens but still there... next month I’ll just do the magnaflow x pipe and see if that helps... if not then I’ll put a muffler on and see if that gets rid of it..
Old 10-09-2018, 12:15 PM   #9
thebanks06
thebanks06's Avatar
Drives: 2016 Chevy Camaro 2SS
Yea you are pretty much stuck with that sound unless you change exhaust or something. I have kooks without cats and when I still had npp that was something that always happened on my cold start.
thebanks06 is offline   Reply With Quote
Old 10-09-2018, 12:20 PM   #10
VinnAY
Drives: 18 1SS/1LE
I think more a frequency in a given RPM range than anything else that is resonating through the system not sure what you can do about that besides adding mufflers/resonators somewhere.
Old 10-11-2018, 04:11 PM   #11
Wheat_Fed_SS
Just on the cold start and not any other time?? If that’s the case I’ll get some aggressive mufflers and just put them on..
Old 10-11-2018, 04:30 PM   #12
Chef-j
Drives: 2018 Camaro 1SS
I was about to say backfire before watch that video. But are you stepping on pedal? Sounds got louder at that second and nasty sounds with one side smoke....?
2018 1SS 6MT: SOLD
Chef-j is offline   Reply With Quote
Old 10-11-2018, 04:32 PM   #13
thebanks06
thebanks06's Avatar
Yea it was on my cold start. I upgraded to AWE for something more aggressive. The headers with no cats was a little to raspy for me especially on those cold starts.
Old 10-11-2018, 05:23 PM   #14
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Even with muffler/cat delete that does not sound normal. Any losse of power when you notice that sound? If you no a guy in the area that has similar set up, I would compare sounds.
I would have liked to hear the exhaust from the rear in the center, it almost sounds like it’s coming more from the passenger side. Did you get rid of all valves if you had NPP?
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
