![]() Drives: 2019 SS 1LE Join Date: Oct 2018
Drag Coefficient
Does anyone know the Cd of the 2019 Camaro SS 1LE? Any Cd numbers for the 6th Generation?
Camaro=brick like
2022 Camaro Zl1 1LE, e85, Roto Fab and tune
2020 Colorado ZR2 Dusk edition 2021 Mustang Mach e |
![]() Drives: 2018 SS 1LE Join Date: Mar 2018
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
With, or without Flowtie?
'18 1SS 1LE Black, PDR
With Flowtie....
#7 |
![]() Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
One thing that I was expecting to be better is the MPH that you would get with 400 RWHP. At the top of 4th gear and into 5th the 1LE just doesn't have the speed I was expecting. I think the front radiator opening/splitter just creates a ton of drag. No science, just personal observation. My 165 RWHP Lotus would run up to 120 MPH fairly quickly before slowing from aero and its coefficient of drag was terrible, frontal area excellent, though. The 1LE seems to slow at about 130 MPH.
#8 |
![]() Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
I noticed mine really started to slow after the shift to 5th at 140. Still hit 167 before I had to let off. Not the fastest I've gone, but the fastest I've gone in my own vehicle.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
#10 |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
Drag Coefficient in the 6th gen Camaro is an interesting conversation.
One must consider, especially with ZL1 and the LT4 cooling needs; does the drag increase for cooling vs. the power generated, override the streamline loss? Good question.
2018 ZL1 1LE sw/PDR
#11 |
![]() Drives: Krypton Green Camaro SS 1LE Join Date: Mar 2017
When you double speed, drag increases by 4X and required HP increases by 8X. From an earlier thread.
LS/LT: 149 V6 1LE: 155 SS Vert: 155 SS 1LE: 175 SS Coupe: 180 ZL1 Coupe: 198 The 1LE has more drag than the standard SS due to wider tires and probably more drag to generate some additional downforce. (or to negate lift) |
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
HP requirement does not go 8x (fold) otherwise the Bugatti would need 3k+ hp to reach 253 miles per hour. It only takes around 600-700 hp to the wheels for most 3500-4000 pound vehicles with the right gearing to go 200mph.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
#13 | |
![]() Drives: 6mt Join Date: May 2017
I've never seen any published Cd. figures for any 6th gen Camaro (probably because it's not very good). An E60 M5 with only slightly more power (~425-450whp depending on the dyno) and a .31 drag coefficient can comfortably break the 200mph barrier but a ZL1 with an additional ~120whp can't. |
#14 | |
I'm a degreed engineer so tell me again your credentials. Better yet, feel free to share the equation you are using. Lets look at the a couple of Camaros. From published data. 1LE has a top speed of 175 mph with 455 hp, ZL1 has a top speed of 198 mph with 650 hp. LS/LT has a top speed of 149 with 275 hp (V1/V2)^3 = HP1/HP2 (175/198)^3 X 650 = HP1 HP1 comes to 449 calculated (vs 455 actual) Using the same equation for the LS/LT, 275 HP (149/175)^3 X 455 = HP1 HP1 comes to 281 calculated (vs 275 actual) There are some aero differences. Suffice to say that the small difference in calculated HP shows the equations are correct. Using the above, for the Camaro to reach 253 would require 1375 HP. Last edited by DjsBadger; 10-11-2018 at 02:28 PM. |
