![]() Drives: 2017 Camaro FIFTY 2SS Join Date: Jan 2017
Torque Converter Shudder with 1500 miles - Fluid Change or TC Change??
So I have a dilemma...
My car has about 1500 miles and I have the torque converter shudder. I took it too the dealer and they first told me they would need to do the flush and fluid change per the TSB. After arguing with them they agreed to skip that and do the torque converter change but needed to order the part. After weeks of back and forth, the part is in. Here is my dilemma.... Do you think my mileage is low enough that the fluid change would fix my issue? It probably didn't start until I was over 1k miles. Do you think the torque converter has permanent damage? What concerns me is researching the amount of things that need to be removed from the car just to get to the torque converter... Seems very excessive. Truth be told, I honestly don't trust the dealer doing that job and am hoping to take the least "invasive" route to get this fixed. Whst are your thoughts... |
I had the flush done. Still experiencing shudder, tho it has improved. I was told to drive the car for a couple hundred miles and the “new fluid” will help with some of that friction. Guess we’ll see. I am say if it’s not resolved, I will be having them replace the TC.
![]() ![]() Drives: 18 zl1 Join Date: Aug 2017
If your TC is shuddering, it's past fixing. you can bandaid it by tuning out the slip tables, or use the proper fluid, but once it starts, it is never the same. you'll also need to keep the car out of v4 mode because it's tuned to allow more slip to alleviate the pulsing inherent with that mode.
All in all, you need the new converter, the new fluid, zeroed out slip tables, and keep your car out of v4 mode to get rid of it for sure. You can *possibly* use a combination of these and never see it again, but it's not proven as nobody has had enough miles to show anything of it just yet. I had the shudder, and 2 triple flushes later it was still there. My car was supposedly made with the new converter and fluid from the factory due to the build date. I currently have almost 6k on a new TC, with new fluid. I've not let my car see V4 mode since the new tc, and the shudder isn't there at all. crossed fingers. knock on wood. etc. |
#4 | |
![]() Drives: '16 1SS A8 w/ NPP Join Date: Nov 2016
Since the second triple flush, I've had zero problems for 10k miles. My car enters V4 mode and I can't tell the difference between V8 mode. I have a 2016 SS. |
![]() Drives: 2017 Camaro 2SS, MRC, NPP, Join Date: Jul 2016
I just got the flush done last month and have put about 600 miles with no shudder issues at all. I will be purring about 400 more miles on the car this weekend so we'll see how that goes.
Took mine to the dealer, they triple flushed and replaced the TC all at once. (I think software was loaded also ) I now have put a little over 11k miles on mine and it hasnt shuddered at all. I hope that I am one of the lucky ones and this was the fix for mine.
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11 RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453 SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/ |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
I had the shutter start up about a month ago and ended up dropping off to the dealership on Monday. They flushed the transmission, lines and filled it back up along with an additive specified on the TSB. They said I may experience some hard shifts for the next 500 miles while things are being relearned but I drove it home on yesterday and it shifted like butter. I took it easy for the first few miles and then I started getting on it and it was rock solid, no shutter and felt strong! I plan to get as many miles on it as I can before I put the car away for the winter and see how it goes. My dealership said they've had about 4-5 cars in for this, have yet to replace a torque converter.
Never grow up, it's a trap!
#8 | |
Moderator
#9 |
Thanks guys. I finally bit the bullet and decided to make the appointment with the dealer to change the torque converter. They said it's going to take a day and a half. Does that sound right? I'm fine with the time I would rather have them take longer and do it right but I just want to know if that seems reasonable
#10 | |
I think you forgot to say how long it would take. It took my dealership 3 business days (5 days total including weekend), from start of diagnosis to ordering TC, installing, and me taking car back. |
#11 | |
![]() Drives: 2016 Camaro Convertible 2SS Join Date: Nov 2016
#12 |
Haha sorry about that. They told me about a day and a half. They have the parts ordered and in stock just waiting for the car.
#13 | |
I’m Magik a physco dog
Drives: '15 1LT/RS & '23 3LT/RS Join Date: May 2016
Thanks.
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe. Previous: 2015 1LT Ashen Grey 2016 1LT Blue Velvet My entire life has been 'A Midlife Crisis' |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
That or using a Range/Diablo AFM disabler.
