Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
Anybody tried a 95mm ZR1 throttle body?
Like the subject says. Has anyone tried a LT5 ZR1 95mm throttle body, either ported and non ported on a ZL1. Its a good bit larger than the stock 87mm one, and the largest OEM throttle body GM has every made.
If anybody has tried it, can you give some feedback? Dyno after install etc.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
#2 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Train Driver
With the thin adapter plate it is bolt on and plug n play. Not sure about the tune.
2018 Camaro ZL1LE
![]() Drives: Pre-production ZL1 M6 Join Date: Feb 2016
Following.
![]() Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
I heard it might have a different bolt pattern. Hopefully someone can verify that. I had a Zo6 guy ask me that today on our Magnuson tech line as he is looking at one of our Heartbeats for his vet and wanted to know if we had an adapter. We don't
#7 | |
https://www.camaro6.com/forums/showt...&highlight=lt5 Last edited by Mcmillion; 10-03-2018 at 03:27 PM. Reason: link added |
#8 | |
Moderator
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
If we don't port the super charger snout as well when we install this we will not see the full benefits of the bigger TB.
is that correct?
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#10 |
Train Driver
I think you are correct. From what I've heard the stock LT4 blower snout opening is same diameter as the stock 87mm Throttle body. So it would hit a 87mm hole on the other side of the 95mm TB. Not ideal.
2018 Camaro ZL1LE
#11 | |
how is it that so many people get the ported throttle bodies anyway, without modifying the super charger?
#12 | |
![]() ![]() Drives: 69 GTO, 05 GTO, 2018 Silver ZL1 Join Date: Jan 2012
With a ported Weapon-X 87mm TB, a CAI from Weapon-X, and the NX lid, we saw right at 50hp on their Mustang dyno. Now the blower and snout is ported and I have the Nick Williams 103mm TB on my X-850 build. |
#13 |
I agree, I have a 102 snout with my Maggie and the difference is huge so the 95mm is just about half way between the 87 and 102 so I would think some additional porting would benefit the change but that's just my opinion.
#14 |
Dyno Show Queen LOL
you should be able to at least match the opening to of the snout or as they call it gasket matching to run the larger tb.. other porting would be more difficult.
