Old 10-01-2018, 11:51 AM   #1
Atlas24601
Drives: 2018 SS 1LE
Sequential gearbox
I wish the SS and ZL1 1LE packages had an option for one of these sequential gearboxes! Very fast shifting, still keeps the driver involved/in control, and it would be nearly impossible to miss a shift which could over-rev and grenade your engine/transmission on certain missed downshifts with an H pattern manual (like accidentaly going from 5th to 1st instead of 3rd at high speed).
https://youtu.be/WSYrktq5zvc
Atlas24601 is offline   Reply With Quote
Old 10-01-2018, 12:58 PM   #2
Dave-ROR
Drives: A few
For a street car.. the noise and cost is a non starter. They are nice on track though.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 10-01-2018, 04:19 PM   #3
DorkMissile
DorkMissile's Avatar
Drives: DZ
DCT technology (computer shifted manual) is readily available in the German market on every level of car from 4 door hatchbacks to high end Porsches since the early 2000s. The American car companies never really took to the technology (Ford tried, went with dry clutches vs wet and had some horrific results)
Had a Golf TDI as a daily with it, worked excellent. Fell in love how fast it shifted and how it barely dropped RPM between shifts.
Currently have a Honda motorcycle with one and would never go back to a standard trans.
DorkMissile is offline   Reply With Quote
Old 10-01-2018, 04:31 PM   #4
DFW1LE
DFW1LE's Avatar
Actually, there is a company in Australia that makes a conversion kit to give you what you are looking for:
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 10-01-2018, 05:14 PM   #5
Dave-ROR
Drives: A few
I assume he meant a real sequential trans (more like your bike) than a DCT..
-Dave
Old 10-01-2018, 07:15 PM   #6
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
I have it on my Leon-FR (DSG) - It does shift lightning fast (especially with the TVS software on it ), HOWEVER, it is a fragile mechanism - Especially since its a Dry-Clutch system - so the torque handling is limited to 300 lb
Still OK for a speedy daily commuter on this 1.8 Liter engine.
Old 10-01-2018, 07:31 PM   #7
FlowForm_Wheels
FlowForm_Wheels's Avatar
Drives: Turbo 4, SC V8 and Twin Turbo V8
Went to check their website for pricing but looks like someone didn't pay the internet bill - https://www.bremershifters.com/
Found on another forum they're asking around $2400ish. Not bad if you've already got Tremec box. Wouldn't ever use that for the street though, that's a bit much.
Also looks like from the videos I'm seeing you still have to depress the clutch on these shifters. I think the Lotus video that was posted originally was a system that doesn't require you to depress the clutch which is substantially quicker. That $2400 price tag seems a lot higher now. If you want a clutchless system here's a good lead to a company I'm aware of - https://www.ppgearbox.com/
FlowForm_Wheels is offline   Reply With Quote
Old 10-01-2018, 10:12 PM   #8
DorkMissile
Drives: DZ
VW uses a wet clutch system - First came on the R32 Golf and there are many that run this setup well over 500hp. The 7 speed version on the Golf R is the same one used by Porsche and Lamborghini.
Old 10-01-2018, 10:16 PM   #9
DorkMissile
Drives: DZ
The VW / Porsche DSG transmission is basically a large motorcycle transmission - you can even service the clutches on the side like a wet clutch on a motorcycle
Old 10-01-2018, 10:17 PM   #10
DorkMissile
Drives: DZ
This would be sequential shifting, however would not provide full throttle upshift and downshift
Old 10-01-2018, 11:55 PM   #11
Atlas24601
Drives: 2018 SS 1LE
Cool! Thanks for the info. I had no idea that was even an option. While you would still need to use the clutch with that it would probably still be significantly quicker at shifting and eliminate missed shifts. Would probably be nearly as quick as a true sequential gearbox when using "no lift shift" mode on the Camaro. Im guessing this wouldnt have any effect on that functions operation as this is just hardware.
Old 10-02-2018, 12:02 AM   #12
Atlas24601
Drives: 2018 SS 1LE
As long as you are between 5000 and 6400 RPMs and at full throttle you can do a "no lift shift". Just keep the gas pedal floored, engaged the clutch, shift gears, and release the clutch. The computers in the car wont let the the engine over rev and start bouncing of the limiter when the clutch is engaged under those circumstances (gas pedal floored and RPMs between 5000 and 6400).
Old 10-02-2018, 12:04 AM   #13
Atlas24601
Drives: 2018 SS 1LE
Anybody know if those bolt on sequential shifter kits will work with auto rev matching?
Old 10-02-2018, 12:26 PM   #14
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Agree. Loved the DSG in my modded GTI. The harder you accelerated, the quicker the shifts. Always drove it in manual mode. Instantaneous shifting. Literally a clutchless manual.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
