09-28-2018, 05:35 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Aug 2017
Tune for lower octane? (due to availability)
I'm planning to get a 2019 (trading in my '16 SS) and am contemplating a ZL1. My main reason (other than price, hah) for not getting one is the octane requirement. Where I live (Vancouver, BC) Chevron is the only gas station that has 94. Everywhere else tops out at 91. That's tolerable, I can work with that. The problem is, once I leave the city for the barren wilds (lol) of BC, it can be a long way between Chevrons, and it could limit where I can go.
So, long story short: Is it possible to have the car re-tuned to safely run on 91 even with spirited driving, without voiding the warranty? I've not really seen any conclusion to the "is it safe to run 91 octane regularly, and drive hard?" question, so it seems like the only really safe option would be a retune?
Current stable:
2019 Camaro 2SS (same as 2016 but 10AT) 2014 Subaru WRX (Satin White Pearl, Kenwood Carplay headunit) Past stable: 2016 Camaro 2SS (8AT, NPP Dual Mode Exhaust, Magride, sunroof, Summit White, black metallic center stripe, Adrenaline Red interior trim) 1990 Mazda Miata (too many mods to list) 1988 Mazda 323 Wagon (With 323 GTX motor!) 1987 Monte Carlo SS (Grey on grey, gunmetal-grey painted GTA wheels, lowered, dual exhaust, and much more) 2006 Subaru Impreza 1981 G20 Van (3-tone brown, shag/velvet interior) |
09-28-2018, 05:41 PM | #2 |
Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
91 octane? I'm in the desert so mine runs fine on 91 oct. My other cars run better with some e85 mixed in to raise the octane, can't wait to log this one and test it out.
09-28-2018, 05:45 PM | #3 |
Thank you Al Oppenheiser!
09-28-2018, 05:53 PM | #4 |
Drives: '19 2SS M6. Join Date: Aug 2018
91 will be fine but what about a little octane boost when you have to fill up with regular?
09-28-2018, 05:55 PM | #5 | |
Current stable:
09-28-2018, 05:56 PM | #6 |
Yeah, I suppose that's a workable option. Still curious if there's a way to detune while keeping the warranty though.
Current stable:
09-28-2018, 06:03 PM | #7 | |
Based on the table a single 16oz can would give you 93 octane on a 16gal fillup of 91. |
09-28-2018, 06:06 PM | #8 |
09-28-2018, 06:16 PM | #9 |
My understanding (which could be way off) of how that works is that it detects the lower octane by detonation. Would that mean that every now and then it's re-advancing the timing (or whatever it's adjusting) to see if the octane is "ok" now, and causing detonation briefly? How bad for the engine is that going to be over the long term? And would running 91 void the warranty anyway?
Current stable:
09-28-2018, 06:17 PM | #10 |
Ah, so it's as workable as the "carry some octane booster" solution. Workable, but still a long-term pain in the butt.
Current stable:
09-28-2018, 06:22 PM | #11 |
Drives: 2019 ZL-1 Join Date: Feb 2009
91 is perfectly fine for the ZL 1. In fact these cars can run on 87 because GM understands that sometimes people will save $ sometimes.
2012 Yukon XL Denali w/ 6.2 AWD |
09-28-2018, 06:37 PM | #12 | |
Drives: Pre-production ZL1 M6 Join Date: Feb 2016
09-28-2018, 09:12 PM | #13 |
Drives: 2022 ZL1 1LE Join Date: Sep 2015
Hi all,
I started using a mix of Sunoco unleaded 100 octane to reach a 93 Octane. In my SoCal desert, the car seems to run a good bit smoother, with less off-idle stumble, and also feels like it has more in the mid range. It is a good bit more costly for sure, at $10.00 per gallon, but relatively easy to add and mix. I fill a six gallon can and use three gallons per fill up, on a quarter tank of 91 octane. Using available on-line charts for mixing, it has made a noticeable difference. I only drive the car occasionally, and any longer trips I might take will not empty the tank on my driving style. I think I may try a TM TB, based on a lot of input from other ZLE owners. I think that may be about all I'll do to this car, along with the already installed Green filter. Seems to be worth it for me... JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
09-28-2018, 09:37 PM | #14 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
91 is fine for everyday driving. I do think that if you have to drive a distance without 91 and let’s say 89 or even 87 octane a couple of cans of a booster would not be too costly to have on hand for long trips and easy to store/carry due to their size. Some guys swear by (Torco).
