Old 09-28-2018, 12:28 PM   #1
lokitwitch04
Drives: 2017 Camaro SS 2SS
DTC B2111 and P0111
Need some help. Loaded an E85 tune into my ecm and now I have a couple DTC that are popping up. I tried to search them but had no luck. Happened twice today. first time was before I put E85 in the tank. It was B2111 and P0216. I cleared them and drove to work. Everything ran Fine. started it at work put in 5 gallons of E85 (still had 93 in the tank) watched the sensor read and drove to lunch. Com out of lunch and the CEL is on. This time its B2111 and P0111.
from what I've found:
B2111 is lumbar down switch failed.
P0216 is injector timing control circuit malfunction
P0111 is Intake air temperature circuit range/performance problem bank 1
Any body seen this before?
lokitwitch04 is offline   Reply With Quote
Old 10-01-2018, 06:56 AM   #2
lokitwitch04
This is only happening on start up the car runs and drives fine. I clear the codes and it doesn't come back until the start up. Seems to be different code every time accompanied by the B2111 code.
Old 02-16-2020, 08:20 AM   #3
Dcsimpkins
Dcsimpkins's Avatar
Drives: 2016 RS Summit White Black Stripe
Did you ever figure out the cause?
Dcsimpkins is offline   Reply With Quote
