Old 09-27-2018, 01:35 PM   #1
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
Arrow [WATCH] Presenting the AWE Exhaust Suite for the Gen6 Camaro SS/ZL1. Available now.
6.2 liters of hell yeah! Presenting the AWE Exhaust Suite for the Gen6 Camaro SS (click here to be taken to the thread with links to pricing information):
  • Proudly engineered, designed, and manufactured in-house, in the USA
  • Dual and quad tip, catback and axleback. Options for all
  • No compromises: all muscle, zero drone
  • Available as sophisticated Touring Edition or the raucous Track Edition
  • Peak gains of 11 hp and 5 ft-lbs of torque, and max gains of 16 hp and 10 ft-lbs of torque to the crank
  • Touring Edition features AWE’s proprietary straight-through drone-canceling solution, 180 Technology®
  • Handcrafted from 3” U.S.-sourced CNC mandrel-bent .065” wall T304L stainless steel
  • Precision-engineered X-pipe is standard in each catback configuration
  • AWE AFM Valve Simulators allow AFM-equipped cars to run full catback exhausts
  • 4.5” double-walled tips in chrome silver or diamond black
  • Less is more: clean, non-baffled, straight-through design maximizes performance
  • Direct bolt-on catback systems when paired with Performance Link Pipes
  • No Check Engine Light -- Guaranteed
  • Perfect Fitment -- Guaranteed
  • Featuring the AWE Lifetime Exhaust Warranty (one year on tip finishes)
    • AWE catback systems WILL FIT Gen6 ZL1 Coupes with the automatic transmission.
    • AWE catback systems WILL FIT Gen6 SS Coupes with the automatic transmission when paired with AWE AFM Valve Simulators.
    • AWE catbacks WILL NOT FIT Camaro Convertible models of any type.
The Touring Edition Exhaust
Touring Edition Catback:
A straight through design, the AWE Touring Edition Exhaust is a full 3” T304L stainless steel configuration featuring a precision-engineered X-pipe that brings out a smooth, yet ultra-aggressive muscle tone with no drone throughout the entire range thanks to AWE’s 180 Technology®. The AWE Touring Edition Exhaust is available with resonated or non-resonated mid pipes.
Sound Perfection: 180 Technology® by AWE.
As exhaust gases exit the Camaro SS’ 6.2L engine and flow into an AWE 180 Technology® equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies. Call it science, call it magic, or call it 180 Technology® by AWE.
Touring Edition Axleback:
In axleback form, the AWE Touring Edition Exhaust retains the SS’ factory mid-section, coming in right at the rear axle. The axleback AWE Touring Edition Exhaust maintains a 3” diameter, shaves weight from the rear, and features AWE’s drone-canceling solution, 180 Technology®.
The Track Edition Exhaust
Track Edition Catback:
If raw and rowdy are your speed, the catback Track Edition is your dose of steel. The loudest of the lot, the AWE Track Edition Exhaust retains all the engineering and precision of the Touring Edition Exhaust, including the X-pipe and 3” diameter tubing, minus the 180 Technology®. The result? Completely raw wake-the-dead level muscle. This version, like the Touring Edition, is available with resonated or non-resonated mid pipes.
Track Edition Axleback:
The AWE Track Edition Exhaust in axleback form provides the most cost-effective aggression in the lineup by retaining the SS’ factory mid section and replacing the rear sections with Track Edition straight pipes.
Please note: This version is known to get rowdy (like, really rowdy), and may be too much for many.
AFM Valve Simulators:
  • Provides a worry-free solution for removing AFM valves from the exhaust route without causing a CEL
  • CNC laser-cut T304 stainless steel construction
  • Direct bolt-on to factory AFM valve motors
  • Comes as a set of two
  • AWE Perfect Fitment Guarantee
  • AWE No CEL Guarantee
  • AWE Lifetime Warranty
The AWE AFM Valve Simulators allow drivers to equip full AWE Catback Exhausts without the worry of throwing a CEL. Simply remove the AFM valve motors from the factory exhaust, bolt them onto the AWE AFM Valve Simulator, and secure them safely to the vehicle.
Once installed, the AFM valve motors will retain their factory operation, and keep your car’s ECU happy.
AWE AFM Valve Simulators come as a set of two, and require the use of the factory valve motor hardware to secure the AFM motor to the AWE Valve Simulator plate.
Performance Link Pipes:
AWE Performance Link Pipes provide an increase in volume by bridging the gap between the primary factory catalysts and AWE catback exhausts.
Please note: the Performance Link Pipes are for racing use only.
Important notes:
Please note that Track Edition Exhausts and Performance Link Pipes can not be returned for sound reasons--they’re not for the faint of heart, so choose your weapon wisely!
Tip Options:
All tip options include the AWE logo and double-walling to ensure a mirror finish even under hard usage. All tips are individually adjustable, allowing depth into the bumper to be set according to personal taste.
  • 4.5” slash-cut diamond black tips
  • 4.5” slash-cut chrome silver tips
Dual to quad tip versions (or vice versa) will require a new valance. But you knew that.
Conversion Kits:
We made it easy to convert catbacks from a Track Edition to a Touring Edition, non-resonated to resonated, or vice vesa if you decide at a later date to turn it up or turn it down.
Volume guide:
What’s in the box?
Complete Touring or Track Edition Catback/Axleback, two or four 4.5” tips in the desired finish, and all required installation hardware.
Data:
Josh/AWE is offline   Reply With Quote
Old 09-27-2018, 01:39 PM   #2
DougCBJ
Drives: 2016 Blue 2SS
just saw the email from phastek, prices aren't as bad as i thought they would be. will be ordering, i am curious about the drone on the Track Edition Axleback
DougCBJ is offline   Reply With Quote
Old 09-27-2018, 01:40 PM   #3
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
Can you please provide the links to the videos? Something about my browser blanks out all the YT content on this site (and only this site, wild).
Thank you!
S2K+1LE is offline   Reply With Quote
Old 09-27-2018, 01:42 PM   #4
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
Thank you!
Here's a link to our website, which will have both videos under the image grid.
Old 09-27-2018, 01:44 PM   #5
S2K+1LE
Awesome, thank you!
Old 09-27-2018, 01:48 PM   #6
DougCBJ
sweet baby jesus, the track version is amazing.
Old 09-27-2018, 01:49 PM   #7
S2K+1LE
They both sound good, but the random skydiver at the beginning of the Touring exhaust video stole the show.
Old 09-27-2018, 01:58 PM   #8
18ss376
Drives: Camaro
Is the axle back track edition available in quad silver tips?
18ss376 is offline   Reply With Quote
Old 09-27-2018, 02:00 PM   #9
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
Originally Posted by 18ss376 View Post
Is the axle back track edition available in dual silver tips?
Yes, of course.
Old 09-27-2018, 02:00 PM   #10
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
There's more than one. I knew it would be epic seeing them in the video when I was filming. Craziness.
Old 09-27-2018, 02:03 PM   #11
S2K+1LE
I caught the one from the rear shot too, that's really cool man! Good work!
Old 09-27-2018, 02:05 PM   #12
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
Wow sounds great! do you have a dyno report with the Track exhaust as well?
artey34 is offline   Reply With Quote
Old 09-27-2018, 02:07 PM   #13
Josh/AWE
Josh/AWE's Avatar
Drives: 1LE
The Touring Edition is straight-through, just like its Track Edition counterpart. Performance is the same.
Old 09-27-2018, 02:14 PM   #14
artey34
artey34's Avatar
What is the max decibels for both the touring and the track?
