Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
Aeroforce vs P3 gauge
I am looking to get a display/gauge to show OBD2 values/PID's.
The P3 gauge has a really nice gauge mount and seems to be nicely intergrated onto the interior. the Aeroforce has a nice defrost vent pod gauge that looks nice too. Both are about the same price once you add the mounting device. But which one is more capable, and will show more PID's? Opinions from people who have them is appreciated. Thx
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
![]() Drives: 2017 Camaro SS 2SS Join Date: Jun 2017
I have the dual aeroforce gauges and love them in the vent pod. It can record your data and play it back if that's your thing and can read out anything in the ecm. I'm not sure on the P3. I like having multiple things displayed at once.
Train Driver
How many parameters can be displayed at once?
Where do you get the gauge that has ZL1 on it?
2018 Camaro ZL1LE
![]() Drives: 2017 1SS 1LE Join Date: Aug 2017
I chose the Aeroforce because it can display two parameters at the same time.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
I have the P3 gauge myself. It’s a very nice piece that is very clean installed. It would be nice if it had more PIDs, but it serves its purpose for me. It can display coolant temp, IAT1, IAT2, boost, throttle position, ignition timing, speed, and 0-60 timing. I usually have it set to coolant temp, as the built in “gauge” is a joke.
I use the Aeroforce defrost vent pod to mount my PLX wideband gauge. Between that and the P3 setup, I have everything I really need. I just break out the laptop if I need real data. |
Train Driver
So the Aeroforce gauge can read all available generic PIDs in the PCM, but the P3 cant? It can only read the ones above (coolant temp, IAT1, IAT2, boost, throttle position, ignition timing, speed)??
Well if that's true it seems like the Aeroforce is the better option even though the mounting is not quite as good, but still a very good pod mount.
2018 Camaro ZL1LE
#7 | |
I guess it depends on what you want to monitor or prioritize. I have my big, bright PLX lambda gauge in that Aeroforce mount up at eye level. The P3 can then discreetly display other data down low. Keeping things clean and low key was a priority of mine though. |
#8 |
Train Driver
If you have a flex fuel ethanol sensor will the aeroforce show ethanol percent if the tune is modified to enable flexfuel capability? You can see ethanol content on hp tuners data log.
2018 Camaro ZL1LE
#9 |
Yes. with the aeroforce you can see the value from the sensor through the ECM. I am doing it.
#10 |
![]() Drives: 2018 ZL1 M6 Join Date: Apr 2018
How does the vent pod mount? Possibly a dumb question but I assume its not permanent and once removed there is no evidence of it ever being installed?
Any pictures of the vent mounting up close? Just need a little further education. |
#11 |
![]() Drives: 2017 Ford F250, 2019 Lincoln Navi Join Date: Apr 2016
I would like to be able to do this. Can you post a sample of what it looks like?
Instagram: MattZ_L1 Vengeance Racing Built
#12 |
I like the Aeroforce, I use it for boost and current gear
#13 |
![]() Drives: 2018 ZL1, 2018 Tahoe RST Edition Join Date: Aug 2018
I have the aeroforce I didn’t want to loose functionality of the air vent. It looks awesome and shows completely everything.
#14 |
