Old 09-25-2018, 06:31 AM   #1
NinoSS
Drives: 2SS/RS CGM LS3
Lightest supercharger system
I'm just curious if there is a noticeable difference in weight between systems. The 1LE is truly an exceptional handling car and if possible I would like to retain as much of this as possible. I'm leaning toward a LT4 blower, but am open to another if there is a lighter option.
I'm not looking for huge power, just 6lbs of boost is fine (550whp is plenty). I had a stage 1 cam in my 5th gen and it drove well, but I do not want to go that route this time.
I tried searching and did not find too much info. Any info is appreciated...
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 09-25-2018, 06:45 AM   #2
laynlo15
Drives: 2022 Lt1 A10
My Maggie added about 60 or so lbs to the front, I think the blower kit weighed about 78 lbs and then all the stuff that came off weighed about 18 lbs. On 6.5 lbs of boost and 93 octane fuel you'll be in the 530 range with a stock 98 mm pulley or you can upgrade as Russ did on his vert I built and you'd be at 549rwhp and about 560 torque with the 95mm pulley at 7.5 lbs. You'll still have great street manners and you'll make the hp above with stock cam and I would recommend going to the rotofab CAI, it uses the stock elbo that you'd get with the Magnuson SC.
Old 09-25-2018, 07:24 AM   #3
Goldfish
Drives: 18 2SS 1LE
This sounds much lower than I would expect, especially since the shipping weight is something like 125 lbs and doesn't include additional fluid for the intercooler system.
Goldfish is offline   Reply With Quote
Old 09-25-2018, 08:00 AM   #4
L78toLT1
L78toLT1's Avatar
Not sure about the total weight increase, but several seem to be hung up on the weight of the additional coolant. I don't know the exact amount the system holds, but I'm guessing less than 1/2 gallon.
Baby Blue
Old 09-25-2018, 08:27 AM   #5
Drsagacity
Drsagacity's Avatar
I was actually looking at the graphs the other day. We had it at 570whp on 7-8psi and then we dropped timing to end at 550whp. The problem was the high pressure fuel pump was not keeping up with demand. I don't know if that was a function of the low pressure supply, or an actual limit on the high side.
I suspect you already have the ZL1 in-tank pump, so that may be a non issue for you and you could easily run 550-570whp at 7psi.
Laynlo spends a bunch of time on the scale as he manages his girlish figure, so I am sure his numbers are correct.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 09-25-2018, 10:53 AM   #6
NinoSS
Are the centrifugal kits lighter than the PD kits?
Old 09-25-2018, 12:13 PM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
No because you do not remove anything to install them.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 09-25-2018, 12:15 PM   #8
NinoSS
That makes sense. Thank you sir!
Old 09-25-2018, 01:11 PM   #9
Eyefixstuff
Eyefixstuff's Avatar
Drives: 16’ 2SS A8 HBM Procharged
Shit. I did something wrong then. LOL.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
Eyefixstuff is offline   Reply With Quote
Old 09-25-2018, 01:12 PM   #10
JANNETTYRACING
Your not suppose to us a sledgehammer LOL
Ted.
Old 09-25-2018, 02:14 PM   #11
oldman
Drives: SS 6 speed of course
I took off my driver's side radiator too. Sorry but the plastic intake weights little.
I too am worried, I did these: 1) headers are so much lighter than the stock stuff + cats. I took off some other stuff that ain't needed, engine covers, valve cover covers the studs that hold that stuff up. You can do silly stuff like remove one of the two horns, put the windshield washer bottle into the trunk. BMR mounts, no strut bar (don't know if the 1LE has one).
You can go for rear seat delete and lithium battery, I know it is at the wrong end.
I've hefted all the blowers under question, and IMO the PD with bracket is the lightest, but total installs probably close...
Old 09-25-2018, 02:17 PM   #12
Eyefixstuff
Ted.
Man I’ll tell you what. The zip ties, exhaust putty, and JB weld really hold up well at 130mph.
To the OP, the kits are probably pretty comparable. None of them are going to take away the handling aspects of your 1LE enough to notice much of a difference. They all however will put a smile on your face under acceleration. We are pretty lucky to have such an awesome platform and great forced induction kits.
Old 09-25-2018, 02:19 PM   #13
oldman
Jeez you forgot the duct tape
Old 09-25-2018, 02:32 PM   #14
Eyefixstuff
Hah. Duct tape is so 1990. Gorilla tape is where it’s at. I was just kidding around anyways. I would never use those things on my car. We all know the correct way to do it would be to save those products for the customers cars for max profit, then overcharge them, and build my car the right way.
