Old 09-21-2018, 12:17 PM   #1
jebfour
jebfour's Avatar
Drives: 2018 1SS 1LE
When to Change Manual Trans Fluid
Hello everyone,
I drive a 2018 1SS 1LE. The car has just over 1,500 miles so I'm going to have the first oil change done tomorrow. I'm also having the differential fluid changed (the dealer seemed surprised by this?). I also considered having the manual transmission fluid changed but wasn't sure it was necessary.
When should the manual trans fluid be changed for the first time?
Current
2018 1SS / 1LE
Previous
1967 w/ 327 & M21
1968 w/ 302 & M21
1968 RS/SS w/ 383 & M22
1986 IROC Z
jebfour is offline   Reply With Quote
Old 09-21-2018, 12:20 PM   #2
Ichabod
Drives: 2018 zl1 1LE
45k miles per the maintenance schedule.
2018 ZL1 1LE
2021 GLS63 AMG
2005 SRT4
2017 Ram 1500
Ichabod is offline   Reply With Quote
Old 09-21-2018, 12:23 PM   #3
jebfour
jebfour's Avatar
Thank you very much for the response.
Current
2018 1SS / 1LE
Previous
1967 w/ 327 & M21
1968 w/ 302 & M21
1986 IROC Z
Old 09-21-2018, 01:25 PM   #4
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Also, if you use it on the track, it's after every 15 hrs of track time per the 2018 owners manual page 199.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 09-22-2018, 10:46 PM   #5
MatthewAMEL
MatthewAMEL's Avatar
Son of a B****.
Isn't that interesting.
The 2017 Manual has NO SERVICE INTERVAL for the Manual.
The 2018 says after every 15 hours of track time.
Good thing I have been changing mine at the end of every 'track season'.
Good catch.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 10-01-2018, 07:35 AM   #6
Jcvibby
Drives: 2017 SS 1LE
What’s the go to Brand of transmission fluid?
Jcvibby is offline   Reply With Quote
Old 10-01-2018, 08:57 AM   #7
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
that's a can of worms that you'll get everyones opinion with. but in mine, was Royal purple.
most people here deal with:
1) factory AC delco
2) Royal Purple
3) Amsoil
4) a few other odd balls
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 10-01-2018, 08:58 AM   #8
DorkMissile
DorkMissile's Avatar
Drives: DZ
Have to be careful with Tremec transmissions - they recommend using ATF, but non-synthetic Dex3 spec, not full synthetic ATF. Most synthetic ATFs have detergents (anything Dex4 approved has detergents in it - it was required to be Dex4 approved), and the detergents can cause swelling of of the composite components which will lead to fast wear of the shift forks.
Royal Purple has a product called Syncromax - which is a full synthetic lube for manual transmissions & transfer cases but it does not have the detergents in it. I've had it in my car for about 1500 miles (put it in at 1500 miles on the odometer) and to me, it is significantly smoother shifting than with the factory fluid. It is much thinner than the OEM stuff. Its not cheap (about $17qt - you need 4 quarts), however many on the forums are using it.
Several are also using RedLine D4 with good luck also.
Just steer clear of anything Dex4 approved.
DorkMissile is offline   Reply With Quote
Old 10-02-2018, 03:59 PM   #9
oneredry
HYPER SS
oneredry's Avatar
yeah, Syncromax (which is GM compatable safe) is what I used. noticed a difference myself.
Ordered: 1/15/2016
Delivered 03/23/16
Old 10-05-2018, 07:41 AM   #10
MatthewAMEL
Redline D4.
It's OEM approved for TR6060 and TR6070.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
C8 Z07
Old 10-07-2018, 08:53 AM   #11
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
I have swapped my manual trans fluid, at the first oil change(1500-2k miles) on the last 4 new M6 equipped cars. I wanted to get the metal shavings out of the trans after some break in miles. Always seems to improve shift quality too.
So far I am using the stock delco fluid to retain warranty.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 10-07-2018, 03:48 PM   #12
JK001
Drives: ZHP, Alfa 4C, RAM, X5, 17SS1LE-sold
Originally Posted by MatthewAMEL View Post
Redline D4.
+1 on Redline D4. Been using it for years in my MT cars. Yet to swap it in the 1LE, but when the time comes it will be D4.
JK001 is offline   Reply With Quote
Old 10-07-2018, 04:07 PM   #13
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
I just did my 1LE yesterday at 1650 miles with Royal Purple Syncromax, my main motivation was to get any break-in crap out. That said it did make a difference in shifting, much less gear feel, very pleased with the results.
Warrior102 is offline   Reply With Quote
Old 10-15-2018, 05:22 AM   #14
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
I just changed my rear diff and M6 trans fluid last night. used the recommended GM fluid for the diff and Redline D4 for the trans. Wow what a difference in the trans, super pleased with the results. Took about an hour to do both, on a lift.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
