Old 09-19-2018, 10:41 AM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Pilot Sport 4S
Recently installed a set. Since it's a very different tire than the OEM S3's, any recommendations for tire pressure for aggressive street cornering?
Thanks.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 09-19-2018, 05:30 PM   #2
TJay74
I run mine at the same 32psi the door card calls for, I am sure you could experiment some.
Maybe start with 30psi all the way around and see how they perform. You could also call the Michelin tech line, they have tons of race data on their tires and will give you suggestions as well.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 09-19-2018, 05:46 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i usually do 34-35 on streets and on track start around 32 or so but depends on track layout size and temps outside
Old 09-19-2018, 08:40 PM   #4
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
how is the grip relative to stock and longevity compared to stock
biker2k is offline   Reply With Quote
Old 09-20-2018, 10:50 AM   #5
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
so, I figured I would make a significant adjustment to the tire pressures, FOR THE STREET. I went to 36F, 35R. Cornering fairly aggressively, it does feel like the car turns in easier and has a bit less understeer. and tire squirm. I need to try some really aggressive cornering to test grip.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 09-20-2018, 09:42 PM   #6
TJay74
You run more than the max weight 32psi the door card calls for on the street? Heck the race prep manual states to start at around 28psi I think and lower from there for track use on the GY F1 tires.
Old 09-21-2018, 03:02 PM   #7
aai
aai's Avatar
Drives: '17 SS/1LE/PDR
7k street miles on ours and wearing well. 30psi on all corners
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
aai is offline   Reply With Quote
Old 09-21-2018, 04:49 PM   #8
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
How's the wet weather performance?
Old 09-21-2018, 05:19 PM   #9
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Far superior to the OEM’s.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 09-25-2018, 11:20 AM   #10
MATTY-1LE
MATTY-1LE's Avatar
Drives: 2018 Camaro SS 1LE
Thanks.
what size did you go with?
Current:
2020 V6 A10 - looooving the regular unleaded, over 20mpg, and excellent daily driver manners!!!!!
Past:
2018 1SS 1LE - stock
2008 C6 - heads/cam/boltons
2005 GTO - cam/boltons
MATTY-1LE is offline   Reply With Quote
Old 09-25-2018, 12:04 PM   #11
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
OEM.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 09-27-2018, 10:02 AM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I now have almost a year on my PS4S's in OEM sizes.
*Warm Dry = less than Supercar3
*Cold Dry = much better than S3
*Wet = much better than S3
*Wear = so far much better
Note: I use them street-only. I have no expectation they would hold a candle to the S3's on the track unless it was wet.
Old 09-27-2018, 10:21 AM   #13
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
How would you rate them on a % scale to the SC warm, dry?
Bad Anvil Garage is offline   Reply With Quote
Old 09-27-2018, 10:35 AM   #14
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
On the street they're about 0.1g less, I'd expect a greater delta on the track. So, call it 10% less warm dry in exchange for being able to get to your destination when it rains. A no-brainer IMO.
