09-16-2018, 10:34 AM | #1 |
Drives: 2016 SS Join Date: Mar 2016
Disappionting Day at the Drag Strip
So I finally got a chance to get a couple runs in at the drag strip and it was very disappointing to say the least. Ended up only getting to run twice because it was a series event so there were a million race cars there and I had to enter the Sportsman class to even get to run. Anyway, I was there mostly to get a couple runs against my friend and his bolt on 14 Audi RS5.
Our first run was against each other and it was pathetic. FYI, bone stock 16 2SS A8, letting the trans do it's own shifting. It was a prepped track, so I figured traction would be much better than runs I've done on the street. I ran in Track mode and left the TC on figuring the car would find all the available grip. It has been many years since I've run a car on a busy track so I was actually a little nervous and of course when you put a helmet on it changes the entire environment in the car. All that being said, my reaction time wasn't great at .266. I could feel the TC struggling for grip and the 60' rolled by in a leisurely 2.305. Obviously the rest of the run suffered from there with the 330' @ 6.111, 1/8th mile at 8.948 @ 87.77 mph, and the 1000' at 11.344, with the 1/4 rolling by at 13.345 @ 112.26. In contrast to that, my friend whipped me with a .043 RT, 2.008 60', 330 @ 5.704, 1/8th @ 8.658 @ 83.97, 1000 ft @ 11.178, and the 1/4 @ 13.297 @ 106.93, beating me by .048. Had I had just a little more track I could have run him down, but no such luck. Anyway, my second run I decided I'd see if Launch Control would get me out of the hole better. Unfortunately, Launch Control didn't help. I actually had a worse run with the LC on. Run #2 with LC: Reaction time .053, 60' 2.447, 330' @6.182, 1/8 @ 9.018 and 88.01 mph, 1000' was 11.413, 1/4 13.419 @ 112.34. All in all very disappointing! One thing I discovered after the runs is that when the dealership changed my oil the previous day, they had inflated the tires to 37 psi. I'm sure that didn't help with grip, but certainly shouldn't have cause the poor launch. I guess the bottom line is I just need some more time at the track to figure out how to get her down the track quickly. Worst thing is that I let my buddy steal the crown I've held for 25 years!! Ugh! Odd thing is I've run him on the road many times and from a standing start he'd jump out a couple cars but I'd always roll by him pretty quickly and it seemed like Track mode and traction control left on resulted in little drama and quick starts. I would have thought the grip of a prepped track would have been better not worse. |
09-16-2018, 10:55 AM | #2 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Your car is running just fine. It's all about the launch and practice with this car. The 37PSI in the tires DEFINITELY didn't help. Try lowering the rears to 22 or 20 PSI, then drive around the water box (if allowed) and then do a quick chirp and clean the tires off for a burnout. 2.3 60' times were the reasons for your slow 1/4, but that trap speed shows that your car is very capable of a low 12 second pass. A 1.8 60' or 1.9 will get you into the low 12's and it has been done tons of times on stock tires, just not at 37 PSI.
09-16-2018, 11:19 AM | #3 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
The best indicator of the car's performance is the mph, at 112+ the car seems to be doing fine. Work on the launch, get that 60' down to 2 seconds or less and you'll be well in the 12s.
09-16-2018, 11:20 AM | #4 |
Yeah, I knew when I discovered the tire pressure that it certainly didn't help matters. Not sure what the dealership was thinking pumping them up to 37 psi!
I did drive around the water box, and did a quick cleaning of the tires before staging. Oh well, next time! |
09-16-2018, 02:30 PM | #5 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
Gotta get that launch down. Almost every time I see someone getting bad times it's due to a bad 60'. A 2.3 is beyond bad. Gotta try to get it under 2.1 which should be possible on stock tires. A pair of drag radials should get you a 1.8 which will make a world of difference in your total ET
09-16-2018, 03:32 PM | #6 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I have found that launch control is best on an unprepped street surface and works poorly on a prepped dragstrip. My car is an M6 though.
I would definitely run with TC off -- I usually double click it to Competitive Mode (TC off, Track version of stability control on). I've found TC on to be very conservative and pulls back power too quickly.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
09-16-2018, 06:37 PM | #7 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Here are some suggestions, lower rear tire pressure to 25psi, back into the water (shut off trac control and stability control hold the button down 10 seconds or more) pull out of the water and do a good burnout standing still till some smoke comes from the tires, stage the car and do not think about reaction time, leave when you are ready. Take off as hard as you can without spinning (modulate throttle to control wheel spin by the seat of your pants) you will feel the bite and get the gas to floor hard. With a auto trans you should be knocking down 1.9 60 ft times all day long and running low 12's @ 114mph. Make sure you have been using 93 octane weeks before you try it again and run with a full tank if you have spin issues. And when you stage, just barely turn on the 2nd light, if you go to far just back up and trip the light again very easy. A good rollout is worth .2 ( just touching the 2nd light) Your there to get a good ET, reaction time means nothing so let the other guy go and leave when your ready.
If you do a proper burn out, with 25 psi pressure (warm) full tank of fuel, on a decent prepped track, you should be able to launch from idle and mashing the throttle when your ready and that will flash the converter for a nice launch. Remember, shut off traction control and stability control so you can do a burn out (hold it with the brake) and leave it off. The 455 HP SS doesn't really have enough to get you in trouble on a prepped track and a prepped car. |
09-16-2018, 07:12 PM | #8 |
Yep, this.
09-16-2018, 07:24 PM | #9 |
What your saying is truthfull, but 112 trap speed is on the weak side. The car should be trapping 114mph. Another thing regarding trap speed is during a poor launch and a poor 60 ft due to excessive spinning can a lot of times result in a higher MPH trap and poor ET versus a perfect no spin hard launch and a all grip run thru 1000 feet which a lot of time results in a lower MPH trap but much better ET. ET wins races, not trap speed.
09-16-2018, 08:46 PM | #10 | ||
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
09-16-2018, 09:24 PM | #11 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
I would actually expect a tuned RS5 with bolt ons to beat a stock SS. You guys were still super close, I would say within the margin of driver error. You are being pretty dramatic about the difference there, or perhaps fishing? I'd call it a draw at a 13.3 to a 13.3. Not what I would call a "pathetic" showing. Also, someone please correct me if I'm wrong, but to see the true potential of your car you would need to run in a PTM mode. I believe on just regular track mode, the traction control still rules, and it messes up your launch.
09-16-2018, 10:32 PM | #12 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Buy some drag radials
Look for the "Dragstrip and Launching" section on this forum and grab some popcorn, you'll learn a bunch and then proceed to get your crown back.
09-17-2018, 07:52 AM | #13 | |
09-17-2018, 08:07 AM | #14 | |
