Old 09-16-2018, 10:31 AM   #1
BCKTLST
Drives: 2017
At my wits end. Need some ideas
I haven’t posted on here for over a year but hoping someone has heard of this or has some ideas. My last posts were about the same starter issues.
First let me say it’s not only HEAT Soaking.
That may be the secondary issue, but something else is the root cause of the starters going out. What is causing them to totally burn up on this particular Camaro? Two of the times that this has happened the engine was cold.
I have had 4 starters replaced on my 2017 SS 50th Anniversary before today and it only has 10,272 miles. It has been on the back of a rollback tow truck 4 before today in 2 years... Tonight I had to have it towed again from my driveway, and the engine was cold and it’s the starter again. This is the second time this year that it has happened. First one was in April and I have only put 1100 miles on it since then.
It Doesn’t seem to matter if the engine is hot or cold when it happens
Chevy garage and Detroit seem to have no ideas as to why this keeps happening.
I have done search after search and find nothing like this posted anywhere. I hate to think about getting rid of this car, but it is totally unreliable
Looking for any ideas that may help the garage.
BCKTLST is offline   Reply With Quote
Old 09-16-2018, 10:43 AM   #2
Pi kappa alpha
Pi kappa alpha's Avatar
Drives: SS Vert
I would just got rid of the car. This is insane.
I want to go to college for the rest of my life.
Pi kappa alpha is offline   Reply With Quote
Old 09-16-2018, 10:46 AM   #3
BCKTLST
Drives: 2017
I’m afraid that’s what it is coming to. The wife is really starting to hound me hard. It just isn’t reliable. Run great when it starts, but has left us setting to many times.
Old 09-16-2018, 10:46 AM   #4
Blazin383
Blazin383's Avatar
Drives: 2016 SS
Wow, I've never heard of an issue like that! Gotta be some kind of an electrical short! Can't believe they can figure it out. Sounds like a case for the Lemon Law! Good luck!
Blazin383 is offline   Reply With Quote
Old 09-16-2018, 10:48 AM   #5
Deakins
Drives: 2017 2ss, m6
Do you happen to use the remote start feature?
Deakins is offline   Reply With Quote
Old 09-16-2018, 10:50 AM   #6
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
It certainly shouldn't be "heat" related. I had my car for two years in FL and never ever had an issue with my starter. 20K miles and no issues.
Old 09-16-2018, 10:55 AM   #7
Pi kappa alpha
Drives: SS Vert
Are you going to disclose this issue when you sell/trade it in?
Old 09-16-2018, 11:00 AM   #8
BCKTLST
Drives: 2017
It’s a manual so no remote start
Old 09-16-2018, 11:10 AM   #9
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Have any factory reps been involved? Is the dealer just swapping out the starter motor without any further investigation? I would hope that by this time they would be looking at mechanical alignment, mounting and other non electrical possibilities. I know how maddening something like this can be, good luck and I wish you a speedy solution.
Sweptwing is offline   Reply With Quote
Old 09-16-2018, 11:23 AM   #10
Wierd Harold
Drives: 2017 2lt rs
Talking
There was a post a long way back about a crankshaft thrust bearing issue.I pretty sure engine was replaced.
Wierd Harold is offline   Reply With Quote
Old 09-16-2018, 11:27 AM   #11
Sweptwing
Sweptwing's Avatar
That is exactly the type situation that I was talking about.
Old 09-16-2018, 12:22 PM   #12
nelsont
Drives: 2018 2SS Hot Wheels Convertible
Dump it if they cant fix it!
Tim
nelsont is offline   Reply With Quote
Old 09-16-2018, 01:22 PM   #13
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
4 starters replaced in 10k miles, it’s not the starter that’s the problem. Something is causing them to fail, dead starters are a symptom of the actual problem.. Since you’re an M6, look into this;
https://www.camaro6.com/forums/showthread.php?t=507133
If it proves too difficult for a dealer to track the problem, I’d look into lemon law to get a buyback.
soloknight6 is offline   Reply With Quote
Old 09-16-2018, 02:01 PM   #14
Wierd Harold
Drives: 2017 2lt rs
Thx solo,that's the thread , hopefully the op can print this off and show his guessing dealer.Glad this old guys memory isn't failing yet,lol. thanks
