![]() Drives: 18 Black ZL1-1LE Join Date: Jun 2017
Throttle Hang
Just picked up a new ZLE having traded in my ZL1. I am having a weird problem that I did not have with my 17 . If you are in 1st or 2nd gear and to a lessor degree in higher gears when accelerating hard and letting off the car does not shut down completely it’s as if the throttle is staying open to the point it takes all the brake you can muster to get it slowed down . Has anyone else experienced this dangerous condition . I’m not an autocrosser but this condition would make it nearly impossible in the first three gears . Anybody else experiencing this ?
Thanks for any input |
DEVLMAN
Drives: White 2018 ZL1 Join Date: Dec 2017
What is your RPM gauge saying? Did you shift while the throttle is hanging? You'll know if it is open as soon as you come out of gear when it revs excessively high or if RPMs don't come down.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I am not sure if there is an issue with yours, but there is a small delay, of like 1/2 to 1 sec. from the time you press or let off the pedal for the acceleration or engine braking to happen on my SS 1LE.
It's definitely not like the old days of instant reaction.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
No shift involved it was a short burst of throttle then on the brakes it just didn't release as expected and it was hard for the brakes to get it pulled down it was as if I was still on the throttle and braking at the same time . very strange
Well if that is in the factory tune I am wondering why my 17 ZL1 did not exhibit this . thanks for the reply
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
Doesnt sound normal to me. Have it looked at. Mine has never did that.
Are you positive you are not hitting the gas pedal with your braking foot. I have did that before. You cant really feel it happening with shoes on. |
#7 |
![]() Drives: Gen V Viper GTS Join Date: Jan 2018
Sounds like Performance Shift Management.
#8 |
No quite sure I’m not hitting both I have tried it many times just to be sure defiantly a hanging throttle
#9 |
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
#11 |
LT4 M6
In those situations I almost bet I am pushing the clutch in also.
#12 |
![]() Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
Do you have Rev-Matching turned on?
#13 |
Actually not for me, I have the tendency to lift first and then push in the clutch. Its at that moment you can feel the car still pulling, not as hard, but not like you just lifted off the gas completely. I felt the same thing in the automatic 2018 impala, lift off the gas and the car is still pulling (less but not what I want to feel) I have 2015 LT1 manual corvette, doesn't do that at all, you lift and it stops pulling no matter what I have done.
#14 |
