![]() Drives: 2018 SS 1LE Join Date: Aug 2018
Buying new 1LE - have a 400 mile drive home. Advice?
So finally found a 1LE that I liked from a dealer I felt comfortable with, however unfortunately they are about 400 miles from my home. Will be driving up shortly to go pick it up. Had some questions for those of you who may have had similar instances - traveling some distance to pick up your vehicle.
1) The car has <10 miles on it. I know break in will involve varying the RPM's. Speed limit will likely be 60-70 on the way home. I've read to avoid setting cruise control in the break in period. Should I just be shifting constantly between 3rd-6th gears varying the RPMS? 2) My biggest concern is rock chips. My first mod was going to be purchasing rock guards. I'm pretty ambivalent to have the dealership install these - I know it's a simple thing, but I don't trust having dealerships do aftermarket mods (even something as easy as rock guards), simply because I've had really poor experiences in the past with this. I either do things like this myself, or I take it to a trusted mechanic. 3) With the above said, would you recommend painters tape along the front bumper and rockers behind the fenders? My plan once I got it home was to do a full new car paint correction, ceramic coating, and then hand it over to have the front bumper protected in Xpel or Suntek. 4) Any other words of advice for those of you who have done long drives like this in your 1LE? |
#2 | |
![]() Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Varying cruising speed and rpms is good. 4th-5th-6th on highway. Do some engine braking too.
2012 Yukon XL Denali w/ 6.2 AWD |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I’ve done it. Change gears periodically and take exits and then get right back on making shifts at 4,000 rpm.
I rolled the dice on stone chips both time and then had Xpel installed when I got home. There is protective film in front of the rear tires so mud guards isn’t the biggest threat. Chips on the front fascia are.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
Until you can get PPF installed, https://www.novistretch.com/ would probably be good to keep it safe on your drive home
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
![]() Drives: 2018 HOT WHEELS SS 6 SPEED COUPE Join Date: Jun 2018
ALL ABOVE IS GOOD ADVICE. MY PERSONAL FEELING IS THAT I WOULD HAVE TO FIND A WAY TO TRAILER THE CAR HOME, IF THAT IS NOT AN OPTION I WOULD CHANGE OIL AND FILTER WHEN I GOT IT HOME. I DO NOT BELIEVE IN BABYING A MOTOR TO BREAK IT IN, I TAKE IT SOMEWHAT EASY FOR THE FIRST HUNDRED MILES, VARING THE SPEED AND THROTTLE TO SEAT THE RINGS. AFTER THE FIRST HUNDRED I DRIVE IT HARD LIKE I WANT TO DRIVE A PERFORMANCE CAR. THIS HAS WORKED FOR ME AND IS ONLY MY OPINION, TAKE THINGS WITH A GRAIN OF SALT AND DO WHAT MAKES YOU HAPPY.
A.C.A.T.T.
2017 QUICK 16 TRACK CHAMPION
STATE CAPITOL RACEWAY RACE TRACK CHAPLAIN FOR 30+ YRS |
#7 |
![]() ![]() Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
Just drive and enjoy it. As already stated vary the speed and RPM's, down and up shift a lot, that's all. Avoid driving at a steady speed and RPM.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
#8 |
Drives: C7 Z06 manual, 18 Zl1 manual, etc Join Date: Dec 2013
Look at my signature op. Like the person above me stated, the 1st 100 miles drive it easy around 60 mph ish with light shifts etc after that bro HAVE AT IT! I personally would do a few 3rd gear hard pulls to 120 +/- depending on weather, traffic, common sense etc. As for rock chips man idk? It's a car and I don't cherish material stuff that much to the point where I'm scared to drive and enjoy it. It's a car and unfortunately shit is gunna happen sooner or later. I do my best to avoid making stuff happen sooner but have the mentality that there is always the possibility for a chipped windshield to occur, a rock chip on bumper etc. Do I care abt my cars? Absolutely but don't wanna have an aneurysm in the event "life happens " Pick her up, drive her home and get the xpel once you are back home and relax bud. Life is too short to worry abt the unknown and small things. Btw everything I've owned seen triple digits under 200 miles of ownership and only 1 issue ever (not associated with improper break in).
#9 |
![]() Drives: ZHP, Alfa 4C, RAM, X5, 17SS1LE-sold Join Date: May 2017
It's not a Bugatti, just drive and enjoy it
#10 |
Break-in a basically garbage myth. As long as you don't bang it to redline and get abusive with it there's really no reason to baby it in varying gears and RPM ranges such as was suggested here. I drive them off the lot like I'll be driving them, for the most part.
#11 |
![]() Drives: 2018 Camaro ZL1-1LE Join Date: Jul 2012
I bought mine from a dealer that was 200 miles away. I chose to take the "backroads" back home vs. the interstate. It increased my drive time by about 30 mins, but it allowed me to:
- become familiar with the car - hit a few twisty roads - avoid the monotony of steady 75mph If that's an option for you, I'd recommend it. Even if you exit the interstate for just 100 miles or so, then get back on later down the road. It'll make the drive far more enjoyable.
2018 Camaro ZL1/1LE
#12 |
![]() Drives: 2000 GMPPSV SS & 2020 2SS Join Date: Jul 2017
Watch for speed traps.
#13 |
![]() Drives: 2018 2SS Hot Wheels Convertible Join Date: Dec 2012
follow the break in procedure in the owners manual.
Take back roads for first couple hundred miles or the whole trip. This will help varying rpm's ect. Donr lug the motor. The Novistretch mask would be a good investment for the drive, and no it wont scratch the paint! And most of all enjoy your new ride! Tim |
#14 |
![]() Drives: 2018 ZL1 1LE Join Date: Mar 2018
When I buy a car and drive it home the only thing I do is take masking tape and tape up the front bumper area to protect it from rocks getting kicked up into it.
other than that just enjoy the drive home
2018 Chevy Camaro ZL1-1LE
2015 Silverado 2500HD 1999 Jeep Cherokee Sport 1998 Dodge Viper GTS 1972 Pontiac GTO 1963 Chevy C10 short bed, T5, 350, lowered |
