Old 09-12-2018, 11:19 PM   #1
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
Question Please explain why lugging the engine = bad
I know you aren't supposed to lug the engine and that it is tough on internal components. I am wondering what exactly qualifies as "lugging" and what will happen if I do this.
For example, many times I am driving at highways speeds in 6th gear and it feels like the engine is lugging when I go to increase my speed, say, from like 60 to 70mph.
Should I be downshifting to 5th to increase my speed? Or is it fine to stay in 6th.
Thanks
protovack is offline   Reply With Quote
Old 09-12-2018, 11:32 PM   #2
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Lugging stresses the internal components of the engine as it tries to turn the crank that's much harder to turn because of too high gearing for the given speed. Think of it as trying to ride a bicycle at really low speeds in the highest gear. Or to start off in the highest gear.
I try not to pass in 6th or increase speed drastically. Gentle increases should be ok. I make it a habit to downshift for passing.
torqueaddict is offline   Reply With Quote
Old 09-13-2018, 01:27 AM   #3
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
It's fine unless you are having to depress the pedal all the way to the floor. At 60mph it will pass just fine in 6th, although not very fast. It really seems to lug if I let the speed decrease to about 45 mph in 6th, but it does just fine around 50mph. Again, if I have to depress the pedal more than about halfway to get acceleration, then I should shift. The other thing to consider is that while the car will purr along at 1000rpm all day long, you do need to exercise the RPM for the rings, so lots of highway miles at low RPM without ever revving up isn't the best thing, it should see higher RPMs too. The torque on tap though means you can get decent mpg without having to go to high RPM to maintain speed.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 09-13-2018, 07:15 AM   #4
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
I do the same, I normally shift @ 50mph to 6th gear and car pulls fine. If i let it go below 47,46 it seems to feel sluggish and need to be downshifted.
Exhaust gets louder..but in a "hurting" sense if that makes sense..
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
Reddy1LE is offline   Reply With Quote
Old 09-13-2018, 07:38 AM   #5
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Thanks
Lugging puts a lot of load on the bearings when you have the least oil pressure down near idle.
Really you don't want to do any kind of heavy acceleration under 1500-2000 or more. Light throttle is fine down low, but the more throttle you want, the more rpms the engine wants.
'18 1SS 1LE Black, PDR
Old 09-13-2018, 08:29 AM   #6
VinnAY
Drives: 18 1SS/1LE
Great post.
Old 09-13-2018, 08:32 AM   #7
VinnAY
Drives: 18 1SS/1LE
I won't grab 6th unless I'm over 75, 6th has no RPM for the driving situation I find myself in on the freeway/highway around here. In 6th @ <70 the pedal is just too mush for my power needs; low RPM.
Most guys can't or won't grasp the concept that just because it's running and going down the street the <2K RPM range is indicative that you need to downshift at least one gear. A huge part of driving a manual is selecting the gear for the RPM range.
Old 09-13-2018, 09:21 AM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Better swap in that ZL1 1LE 6MT... 6th gear 2500 rpms at 80mph, you'll go looking for 7th gear.
As other said, high loads, low-ish oil pressure, althought mine seems to read 35+ all the time, cold, hot, etc. fancy variable displacement pumps.
ing for grip.
http://www.motorsportsne.com/
Old 09-13-2018, 09:53 AM   #9
JamesNoBrakes
Drives: 2SS 1LE
You do realize why they put a 6th gear on the car, right?
2018 2SS 1LE
2023 Colorado ZR2
Old 09-13-2018, 10:49 AM   #10
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Go drive an automatic transmission version of the engine you have. Observe the ratios selected for given engine loads and torque request. This gives you evidence of what the OEM deems acceptable engine operation. You will find that at low load the RPM is at low BSFC / high fuel economy, and at high load the RPM is at peak torque to the axle.
You won't find an OEM admitting exactly what "lugging" is, it's too vague a term and is mainly a catch-all term to give them an easy legal path for warranty denials. If the oil pressure is too low and causes metal-metal contact in the bearings, then the engineers failed to design the pump correctly. If there's LSPI, then the combustion chamber was incorrectly designed and ECU calibrators failed at their job.
Old 09-13-2018, 11:17 AM   #11
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Comparing automatic and manual for load is... not the same.
Where torque converter acts as damper for loads, clutch... NOT so much.
Try again.
ing for grip.
Old 09-13-2018, 11:33 AM   #12
RedHot_1SS_1LE
Mike
RedHot_1SS_1LE's Avatar
Drives: 2018 1SS 1LE
Try again.
No... Ryephile is right.
The TC is locked above 2k RPM (not sure of exact RPM) so for peak torque at high load, the auto programming will be very close. Even for low RPM high efficiency driving, a computer controlled TC clutch will 'lock' the TC so that should be close too. Maybe not exactly the same, but definitely close enough to get a good idea of where the powertrain engineers feel the engine is happiest/safest.
RedHot_1SS_1LE is offline   Reply With Quote
Old 09-13-2018, 11:59 AM   #13
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
lol i never even use 6th gear because the drone is so bad
Old 09-13-2018, 12:42 PM   #14
Boost Creep
Drives: '18 1SS 1LE
I was going to post something similar.
Low load low rpm, high load high rpm.
If you are just cruising it's inefficient and un-practical to cruise in a lower gear turning 4000 rpm, doesn't make sense unless you are waiting on the third horn beep while driving in Mexico. And when trying to pass someone on a hill going 40, sixth gear and 900 rpm aren't going to help you gap that Prius.
