Old 09-12-2018, 10:46 AM   #1
samjlee27
samjlee27's Avatar
Drives: Summit White 2018 Camaro 1SS M6
Disappointing times?
Just took my 2018 Camaro SS 6M to an 1/8 drag strip and ran some bad times. 9.10 and 9.51. My car is also getting bad gas mileage @ 17.4mpg for mostly highway driving. Could there be something wrong with my car? My engine has also been ticking really badly and the tires slip with the slightest amount of rain.
samjlee27 is offline   Reply With Quote
Old 09-12-2018, 10:53 AM   #2
Osbornsm
Drives: 2018 SS 1LE
  1. Took my 2018 Camaro to an 1/8 drag strip and ran some bad times. 9.10 and 9.51.
    1. Bad times could be a million things
  2. My car is also getting bad gas mileage @ 17.4mpg for mostly highway driving. Could there be something wrong with my car?
    1. There always "could" be something wrong, but not likely
  3. My engine has also been ticking really badl
    1. Can't help yah here, sounds like a dealer visit?
  4. The tires slip with the slightest amount of rain.
    1. Goodyears S U C K in the rain. I hydroplane at anything over 60 mph.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 09-12-2018, 03:44 PM   #3
Nsxmatt
Drives: 2017 Camaro
Your 60ft was probably in the 2.5-2.6 range. You just need practice. If something was wrong with your car to cause a massive mileage difference the CEL would be on. The ticking you hear is most likely the direct injection pump and injectors which is normal.
Nsxmatt is offline   Reply With Quote
Old 09-13-2018, 10:18 AM   #4
Jeb114
Jeb114's Avatar
Drives: 2021 300
Ticking with the symptoms your stating sounds like the High Pressure fuel pump going bad .Warranty issue.
Jeb114 is offline   Reply With Quote
Old 09-13-2018, 10:32 AM   #5
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
You need practice like mentioned already. Gas mileage in a manual is tied very much to your drive style. I average about the same unless I'm on the highway and in 6th gear on a long trip, then it climbs to over 20. Also, the manual does not have AFM (active fuel management)enabled like the automatic. It's running on all 8 cylinders full time.
Post a sound clip of the ticking if you can. 90% of the ticking complaints on the LT1 is related to the direct injection which is normal. It is not going to be quiet like the typical family sedan.
You need to drive conservatively in the rain with this car. The torque of the engine will break the tires loose easily even in dry weather.
torqueaddict is offline   Reply With Quote
Old 09-17-2018, 09:28 AM   #6
samjlee27
samjlee27's Avatar
Thanks for the response everyone, here is a clip of the engine ticking;
Old 09-17-2018, 01:34 PM   #7
sal11585
Drives: 2017 Camaro SS 2ss Nightfall Gray
Isnt that the direct injection? I hope it is cause my car makes that tick also
sal11585 is offline   Reply With Quote
Old 09-17-2018, 02:45 PM   #8
modru2004
Drives: 2018 2ss
mine as well. pretty sure there was a thread in the trouble part of the forums where this was discussed as normal on these cars.
modru2004 is offline   Reply With Quote
