BYND GARAGE
Drives: 17' 1LT Turbo Join Date: Feb 2016
will it scratch?
thinking about getting a exterior duster for the car since I live in a very VERY dusty area. ive always heard that they scratch the car vary easily tho but I was thinking abt using it with the combination of my adams detailing spray as well. what do you guys think?
Retired from Car mfrs....
A properly broke in California duster will not scratch the car, however, if it is very heavy dust you're better off doing a rinseless or hose wash. Stop listening to what "they say". ....
Thank you Al Oppenheiser!
The Museum Rule: The less you touch a thing, the longer it lasts. But you're probably not planning to found a new car museum, so your main goal will be to prevent the dust/sand from creating swirls in the paint.
Best solution (also most expensive, a few $ thousand): self-healing paint protection film. Wipe it, brush it, california-duster-it, doesn't matter it will always look great. Next best solution ($1-2 thousand, or a few hundred if you DIY): A good ceramic coating topped with a durable hydrophobic coating. Best low cost solution (about a digit less expensive, a couple hundred, <$100 if you DIY): a top-shelf durable hydrophobic coating like Gtechniq EXO. Least best solution ($35, amazon DIY): Carpro Reload or similar silica-based sealants. Some of these can be sticky when freshly applied, until first rinse/rain. Always: 500 gram/sq-m microfiber towels and lots of lube (distilled water or distilled+sealant mixes). |
BYND GARAGE
Didn’t really say as much as I should of haha
That car is ceramic coated and I want to use the duster ever 2 or so days just to get the loose dust off till my next wash do every week. I do a touch less wash too btw
![]() Drives: Hyper blue 1ss convertible 6 sp Join Date: May 2017
duster is perfectly fine when used correctly, no wiping like it's a rag! Keep the body of the duster off of the paint and let the little duster ends dangle and dust the car off lol.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Battery powered leaf blower works great for dust, then if there is still light dust, you can always lightly go over it with a thick high GSM MF towel.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Since it is ceramic coated, I would recommend just leaving it dusty until you can wash properly.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
#9 |
Drives: The shiny ones. Join Date: Mar 2010
I got the opportunity to machine polish a pretty famous car because of a duster, I use and recommend using Waterless Wash & WW MF towel.
https://youtu.be/2vCuSifHQHI |
