Old 09-08-2018, 01:17 PM   #1
Silver2ssA8
Drives: 2017 Silver SS
Cold start tick, normal or not?
I know there’s quite a bit on this, but I was hoping I could get an opinion on this.
My car has a little over 2000 miles on it, and this just showed up about a week ago, initial start up sounds normal, as soon as the idle settles this metallic tick shows up and doesn’t go away until I drive it a mile or so
Here’s my video
https://youtu.be/xoxZJjun94E
I contacted a dealership and they told me not to worry as long as there isn’t a check engine light, and to keep driving. It does seem to me that it’s getting louder every morning but that could be my imagination. The video I posted was this morning after the idle settled
Silver2ssA8 is offline   Reply With Quote
Old 09-08-2018, 01:29 PM   #2
KCelsius
KCelsius's Avatar
Drives: 2018 Summit White 1SS 1LE
Quite a few other threads I've read about. General consensus seems to be normal due to the DI system.
KCelsius is offline   Reply With Quote
Old 09-08-2018, 02:26 PM   #3
Silver2ssA8
Yeah that’s what I was thinking, just odd how it just happened and seems to be progressing and only occurs on a cold start
Old 09-08-2018, 02:36 PM   #4
njweatherman
Drives: 2018 Camaro 2SS, redline edition
I have a brand new, 2018 2ss, automatic. If you pop the hood, you will notice the ticking noise louder on the right side of the engine (driver's side). I took mine in today and the dealer said it could be a bad lifter. They have to take the front part of the engine off to diagnose it. I'll keep you posted.
njweatherman is offline   Reply With Quote
Old 09-08-2018, 02:57 PM   #5
Silver2ssA8
Yes please do! I’ll make another video when I leave work because I’m sure it will do it again after sitting all day, it’s really hard to pin point but I can hear it standing 15-20 feet away from the car with the hood closed
Old 09-08-2018, 05:43 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Here’s my video
There was a widespread problem with AFM lifters in Gen5. However, that problem exhibited immediately on startup and went away after 10 or 15 seconds in most cases. The noise was very loud for that brief period, much more violent than in your clip, yet, it most certainly did NOT result in a check engine light. The initial noise was caused by defective lifters collapsing due to loss of pressure when sitting for more than a few hours.
I had this problem and it was corrected by replacing the lifters with re-designed lifters. Presumably, Gen6 engines continue to be built with good lifters.
Your symptom sounds like something else. In general, hydraulic lifter engines tend to make some noise before fully warmed up. As the weather gets cooler, it takes more time to warm up. The sound in your video sounds like a typical GM small block when cold, IMO.
DI engines (there's one in my wife's Equinox) have a persistent tick that is normal. The fuel pressure is ridiculously high so the DI check valves make some noise.
Old 09-08-2018, 06:18 PM   #7
Silver2ssA8
Yeah I don’t know what to think, it is much louder than that DI tick which I’m used to now. It’s weird because it seems most prominent when I’m leaving from work, after the car has sat in 90+ degree weather, rather than when I’m leaving in the morning. My garage stays around 75 degrees all night too. I have a couple buddies with the same car, they have 30k and 60k on the odo and don’t experience the same ticking so it has me worried
