Old 09-05-2018, 09:57 PM   #1
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 18 ZL1 A10 & 18 2500HD Duramax
Anyone running 315/35/20 tires in the rear?
Just like the title says is anyone using 315/35/20 tires in rear? I plan on modding my ZL1 soon and it should be over 700rwhp. I would like to use 315/35-20 NITTO NT05R but I’m not sure if going with a taller tire will cause any issues.
https://www.onlinetires.com/products...60-p68208.html
Procharged 2018 ZL1 A10
2018 2500HD Duramax
TripleBlkZL1 is offline   Reply With Quote
Old 09-05-2018, 11:32 PM   #2
Boosted4life
Drives: 2018 ZL1 A10
I ran the 305-35-20 et street and didn't like them much. They rubbed but not enough to cause issues as long as you relocate the wiring harness. I switched to the r888r 315-30-20 and I'm much happier with how they perform.
Boosted4life is offline   Reply With Quote
Old 09-06-2018, 08:51 AM   #3
TripleBlkZL1
Option
I definitely don’t want any rubbing and the r888r’s were my second option. I’m not looking for tires that can handle a dig run but somethings that can handle 30 or 40mph roll. Thank you for the reply!
2018 2500HD Duramax
Old 09-07-2018, 04:18 PM   #4
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
Rub a bub
Was going to install Nitto Motivos on the car all the way round. I tried to install this size tire on my car, and they were going to rub on the inner well area, especially if you went over something causing the suspension to give. I had them mounted on the stock rims, and you couldnt put your fingers, between the inner well , and the tire they were just too big.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 09-07-2018, 08:51 PM   #5
Boosted4life
Originally Posted by TripleBlkZL1 View Post
Option
No problem. I would highly recommend the r888r then. It is an excellent tire and I have had great luck with them. They hook much better than stock.
Old 09-07-2018, 11:07 PM   #6
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I've heard they are pretty noisy tires, comments?
Old 09-08-2018, 11:36 AM   #7
Boosted4life
Yes that is one downside they do have a hum noise to them at higher speeds. I got used to it tho.
Old 09-08-2018, 01:00 PM   #8
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
what brand are you running in the front. I wondered since stock tires are such a stiff side wall that the r888r aren't as stiff that the car would get squirrely after you get rolling. I had this problem in my c6.
speedraider is offline   Reply With Quote
Old 09-09-2018, 10:01 PM   #9
Boosted4life
I'm running stock tires on the front. Probably will go to r888s all the way around when those are worn out. I did have that problem with I ran et streets with stock fronts but not nearly as bad on the r888s. That's actually part of the reason I got rid of the et streets.
Old 09-09-2018, 10:09 PM   #10
Those are definitely not going to work. That's a 28.7 diameter.
I tried my old 5th Gen DRs (305/45-18) that were 28.8 diameter and it wasn't even close to fitting.
I didn't even let it down off the jack as it was already rubbing the fender well. These 20" are tough to find the right tires at 27".
Old 09-21-2018, 10:22 AM   #11
alfreddiesel
Drives: 2019 ZL1
Tried 315/35/20 DWS 06 - rubbed. Anyone find an all season in 305/30/20?
alfreddiesel is offline   Reply With Quote
Old 09-22-2018, 12:19 PM   #12
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
The BFG Comp A/S 2 in 305/35/30 is about as close as you're going to get and fits from what others are saying that have ran them. They don't have a stock from size so you have to go down to a 275/35/20 front to match.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 09-23-2018, 07:00 PM   #13
Johnny Camaro
Drives: 13 ZL1vert,19 ZL1 vert A10 10/24/18
So 315 don't fit but don't they fit with spacers anyone ?
Bc I just bought brand new tires on my 13 ZL1 to take them with me on my 17 ZL1 refresh that hopefully is ready end of October. :(((
Johnny Camaro is offline   Reply With Quote
Old 10-06-2025, 07:31 PM   #14
jhylton2
Drives: 2018 Chevy Camaro 1SS 1LE
Where exactly did your 315/35/20 Continental DWS06 tires rub?
I have a set of MRR FS06 wheels, Camaro SS 1LE offset (F 10", 23o/R 11"/43o). The 305/30/20 does not rub, with or without a 5mm spacer. I have relocated the wiring harness. I do have Eibach springs and Mag ride.
The 305 Contis are not wide enough for the wheel, the rim sticks out. Conti does not make the DWS in 315/30/20.
I have 295/30/20s on the front, they are good, no rubs.
jhylton2 is offline   Reply With Quote
