Old 09-05-2018, 12:09 PM   #1
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
For those of you with a catch can....
Can I get away with putting the supercharger lid back on without a torque wrench? Would I run into any problems if I hand torqued the bolts?
SSallday is offline   Reply With Quote
Old 09-05-2018, 12:47 PM   #2
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Do it hand torque
First bolt I torqued with wrench I broke it
I removed the lid and put it back 3 times with hand torque no issues...
Biscuit.fr is offline   Reply With Quote
Old 09-05-2018, 07:58 PM   #3
chicagosam
chicagosam's Avatar
Drives: 2017 BLACK ZL1 A10
By Hand - No issues..
'17 Mosaic ZL1 Katech TB, Plugs/Wires, Rotofab Oiled,+18% Lower, 2" Headers, Cat Delete, 93 Tune, Mobil 1, IPA FF04, 315/30/20 r888r, 664hp/693tq (93), 702hp/727tq (100 oct)
chicagosam is offline   Reply With Quote
Old 09-05-2018, 08:30 PM   #4
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Use a 1/4 inch drive and use german "gutenteight" standard, you'll be fine.
Old 09-06-2018, 09:39 PM   #5
SSallday
SSallday's Avatar
ok, great. Thanks for the input!
Old 09-07-2018, 11:02 AM   #6
headgamez
Drives: 2018 Camaro ZL1
Hilarious!!!
headgamez is offline   Reply With Quote
Old 09-08-2018, 09:30 AM   #7
Fraxum
Fraxum's Avatar
So the lid is the only thing that has to come off to install a catch can?
Old 09-08-2018, 10:01 AM   #8
headgamez
No it isn't. It seems to be pretty involved. The supercharger base must be lifted about 2 inches apparently. I am on the fence about this since I have been hearing about all the warranty denial stuff.
Old 09-08-2018, 10:56 AM   #9
Biscuit.fr
Look on YouTube
Elite 2x catch can install on ZL1
You will see everything
Just look
Dare
And do
What I did on mine: super easy
You have to remove the lid and unscrew le SC to lift it a couple of inches to access, remove and switch the PCV valve...
Then reverse the process
Old 09-08-2018, 11:00 AM   #10
headgamez
Originally Posted by Biscuit.fr View Post
Look on YouTube
Just look
Dare
And do
Hey Biscuit,
What did you use to install the aluminum diverter? It looks like a spanner wrench of some sort may be necessary to fit the slots.
Old 09-08-2018, 11:12 AM   #11
kwav8r
Flyin NOE
Originally Posted by headgamez View Post
Hey Biscuit,
When you pull the OEM diverter you'll find that it isn't in there with much torque at all. I used a chisel to tighten mine down, nothing fancy.
Old 09-08-2018, 11:26 AM   #12
headgamez
Ah gotcha!! Then install the barbed fitting, which I am assuming needs to be modified because in some instances it was hitting the water pump?
Old 09-08-2018, 05:45 PM   #13
Biscuit.fr
Yes
The gold part needs to be cut 45deg because there is not so much room and it touchs the bottom part of the engine.
Like the video on YouTube : Cut it 45deg with a dremel then it works
Then dremel is again your friend :
I built my own tool to torque (very slightly) the new silver pcv valve.
I cut both side of a 19 wrench
Then I got my 2 fitting stuff you need
I will post a picture tomorrow I’m not home
Old 09-09-2018, 06:23 AM   #14
Biscuit.fr
here is the tool I built from a 19 wrench
to remove the OEM PCV I used a long std Square
then to torque slightly the new PCV, I cut at 45deg the gold part and cut 2 extra marks on the silver front with my Dremel just in case something went wrong with the only 2 OEM (now I have 4 to play with...)
that's it, hope it helps...
