SNSTRSS
95mm vs 95mm ported
Is there a huge difference between the 95mm tb and a ported one? I currently have a PP ported stock on a G1pro ltx sheetmetal intake. I'm planning on eventually going procharged. Should I just stick with the non ported 95?
2016 Black Camaro 2SS A8 NP
#2 | |
Drives: All GM Performance Join Date: Jul 2011
I don't think you will see a difference with a ported 95 over a standard 95. Not without a real demand for the airflow. (RPM, Heads/cam, etc...) |
#3 | |
![]() Drives: 2016 2SS A8 Join Date: Feb 2016
Add heads/cam and more RPM, then you should start to see a difference between the two 95mm. With boost, the difference between the two should be larger, but I can't speculate how much of an improvement ported vs Non-ported would be on boost. For how cheap the 95s are you could purchase it, and just have it ported later when you switch to a procharger.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA |
SNSTRSS
Thanks for the information. That's what I figured. I can always have ported later.
![]() Drives: 2013 2lt Join Date: May 2014
The only real difference you will see throttle response. You're just letting in a bit more air with the same throttle position. It's like tweaking your throttle.
