Old 08-31-2018, 09:30 PM   #1
reeper
reeper's Avatar
Drives: 2010 HD D/A, 2015 Z06, 2016 2SS
What causes this????
These follow the line of the trunk lid. There doesn't appear to be contact?
2016 Hyper Blue A8 2SS
GM Bodykit: Black
MRR 017 wheels: Black
OEM Blackout tail-lamps
OEM SEMA Grille
35% window tint
Black glow-tie
BMR Suspension (Pretty much everything)
ACS rear-deck spoiler
Rotofab CAI
Lolly-pop red rotors by Madison Powder Coating
reeper is offline   Reply With Quote
Old 08-31-2018, 11:29 PM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Probably when lid closes.. gasket compress.. contact ?
ing for grip.
http://www.motorsportsne.com/
Old 09-01-2018, 12:21 PM   #3
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Just noticed the same on my SS, 13,700 miles....
Old 09-01-2018, 02:10 PM   #4
Gen6_1Le
Gen6_1Le's Avatar
Drives: 2018 Camaro 1Le
Wax or detail spray residue maybe , does it come off ?
Gen6_1Le is offline   Reply With Quote
Old 09-01-2018, 07:40 PM   #5
reeper
reeper's Avatar
Nope
GM Bodykit: Black
OEM SEMA Grille
35% window tint
Black glow-tie
Rotofab CAI
Old 09-01-2018, 07:50 PM   #6
Wierd Harold
Drives: 2017 2lt rs
Have to check mine,could be heat distortion.When it cools off ,back to normal clearance
Wierd Harold is offline   Reply With Quote
Old 09-01-2018, 08:08 PM   #7
g26er
Drives: 2018 Camaro SS
If you drag your fingernail across it, can you easily feel it or is it pretty smooth? If smooth, it'll probably come out pretty easy. Meguiars M105 seems to be readily available at all the big name auto parts stores so it should be easy to find a bottle. Clean that area so there's no dirt and put a little M105 on a clean microfiber towel/pad and gently polish it out.
If I remember, there's little knobs you can adjust on each side to control how far down the lid goes... maybe they need to come up a little. Maybe try and close it a little softer. It'd suck to get the scratch out only for it to come back again.
g26er is offline   Reply With Quote
Old 09-03-2018, 11:07 AM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
OP: It's from the trunk lid.
1. Adjust your trunk lid stops up a bit.
2. Don't slam it shut.
3. Go to a detail/tint/PPF shop and pay 'em $100 to polish it out and apply a self-healing film like XPEL to the area.
Old 09-03-2018, 06:54 PM   #9
DougCBJ
Drives: 2016 Blue 2SS
had it on my black RS, the blue SS i traded for also has it.
DougCBJ is offline   Reply With Quote
Old 09-03-2018, 07:43 PM   #10
reeper
reeper's Avatar
Update on this. I did get most of the scratches out with Scratch X. I'm certain with more work and elbow gease it will all come out. The other important thing is my adjustment knobs were set to the lowest setting. I raised them so we'll see.
GM Bodykit: Black
OEM SEMA Grille
35% window tint
Black glow-tie
Rotofab CAI
Old 09-03-2018, 08:52 PM   #11
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
i believe I have a fix... clean up the area and put a thin strip of clear bra on this area....
