08-31-2018, 09:30 AM | #1 |
Drives: 2018 ZL1 A10 Join Date: May 2017
Aftermarket oil pump
Does anyone make an aftermarket oil pump for the LT4 wet sump? I just had my second oil pump failure on my 18 ZL1 and I'm sick of dealing with these stock pumps blowing up.
08-31-2018, 10:28 AM | #2 |
Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
^ This needs to be addressed by GM. There has been an unusual amount of oil pumps going bad in the 2018 ZL1"s.
19 ZL1-1LE A10
08-31-2018, 11:10 AM | #3 |
Thank you Al Oppenheiser!
08-31-2018, 12:25 PM | #4 |
USN VET
Drives: 2016 SS sedan, 2018 ZL1 1LE Join Date: Jun 2017
How would you know if your oil pump has failed or is going to fail?? CEL? Low PSI?
HUZL1N_1LE
08-31-2018, 12:48 PM | #5 |
Drives: 2018 Camaro ZL1 Join Date: Mar 2018
A warning and chime will come on prompting you to turn off the vehicle immediately because of low oil pressure.
2018 Camaro ZL1 - Rotofab, Ported TB, Tune, 1LE smoked taillights/third brake light, JWM smoked sidemarkers, Solo Performance Cat Back Exhaust.
08-31-2018, 12:56 PM | #6 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Melling ?
2012 Yukon XL Denali w/ 6.2 AWD |
08-31-2018, 06:55 PM | #7 |
Both times my car has made a horrible rattle noise and oil pressure dropped to 0
08-31-2018, 07:14 PM | #8 |
Drives: 2017 Colorado ZR2, 2018 ZL1 Join Date: Jun 2009
08-31-2018, 08:39 PM | #9 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
Oh my. Mine is still good at 3600 miles. Knock on wood.
08-31-2018, 08:47 PM | #10 |
Sarcasm loading --------
omg.
Chevy should swap out all these junk LT4's for fresh LT5's and call it a day.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
09-01-2018, 12:17 AM | #11 |
09-01-2018, 12:54 AM | #12 |
Drives: 2017 ZL1 Join Date: Jun 2018
This is a serious concern, right now I was ready to start shopping.
I won't have any warranty as I will import car to Europe... So 60000USD is no longer a good deal if oil pump gives up and I spun all the bearings...means new engine. This is definitely making me think I should stay away... What breaks in the pump? |
09-01-2018, 08:29 AM | #13 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
I believe this only effects 2018 cars.
09-01-2018, 09:26 AM | #14 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Same oil pump on LT1 and LT4? If it’s the case I don’t know why 16-17 have no issues... New cars are weaker?????? Suppose to improve |
