Old 08-30-2018, 06:20 PM   #1
SkiRideDrive
Drives: WTB Camaro
Low Cost NPP modification for more volume
Hey there.
I was pondering the least expensive way to get a bit more volume out of the NPP muffler when in full open mode. Some aftermarket companies have solutions in the 1200 dollar range and some folks have replaced the suitcase with aftermarket mufflers, etc.
I'm not sure if there is enough clearance under the car, but was thinking that maybe adding pipe to bypass the muffler for each valve could give a bit more volume for minimal investment. This would also allow the car to remain quiet in stealth mode. I have a super quality MS Paint drawing below with black lines showing where the theoretical bypass pipes would go.
Any thoughts?
SkiRideDrive is offline   Reply With Quote
Old 08-30-2018, 06:37 PM   #2
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
Air will follow path of least resistance.
Doubt much of it will be flowing thru the 90 degree added pipe ,
and even the little that does will not affect the volume coming out of the same exhaust port.
Indyblue98 is offline   Reply With Quote
Old 08-30-2018, 06:42 PM   #3
TJay74
I am willing to bet it wont give you less than a 10% increase in sound volume. When that valve is open, minimal exhaust flow goes thru the internal muffler.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 08-30-2018, 06:49 PM   #4
SkiRideDrive
Drives: WTB Camaro
I hear both of you, but I think that maybe flow and sound aren't always directly related. If a muffler deleted camaro is significantly louder than an NPP camaro in full open mode, I have a feeling that bypassing the muffler may produce additional volume. There is also the option of adding a Y in the system instead of a T.
Old 08-30-2018, 08:02 PM   #5
Bobkd
Drives: 2018 1ss, 2021 silverado HD
If you could block the exhaust coming out of the muffler case next to the npp valve that would get you what you're looking for. With the valve closed it could still go into the muffler and out the inside outlets for stealth mode.
Bobkd is offline   Reply With Quote
Old 08-30-2018, 10:14 PM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Install CA cat deletes and the NPP will get much louder when open.
Old 09-01-2018, 06:19 AM   #7
VinnAY
Drives: 18 1SS/1LE
Too many people have said it get's raspy this route when I was thinking of the 2d cat delete option
Old 09-01-2018, 07:13 AM   #8
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Headers and no cats will make it 10x louder. I also wouldn’t judge the sound from inside. The sound deading used on these cars is incredible I didn’t realize how loud my car was until I heard it going down the road.
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 09-01-2018, 07:45 AM   #9
parish8
Drives: 17 SS a8
I removed all 4 cats and it was very loud open and still quiet closed. I wouldn't expect much of a change in sound with a bypass.
Old 09-01-2018, 09:07 AM   #10
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Is it just me or does anyone else think the NPP is too raspy sounding in stock form? It sounds really good at low-mid throttle but once it goes WOT at high rpms it starts sounding obnoxious and raspy?
I have tried to play with HP tuners tables and command the valves closed at WOT, but its still just as loud.
With the valves closed it does look very restrictive having to flow through those small holes. I have measured with 5hp difference (as advertised with the corvette NPP) with virtual dyno comparing stealth mode to track with virtual dyno.
cmitchell17 is offline   Reply With Quote
Old 09-01-2018, 10:47 AM   #11
zoutlawss
zoutlawss's Avatar
Drives: 2018 1LE
Damn delete that big ugly thing and enjoy the Roar. I did the muffler delete and secondary cat delete and car sounds awesome. You can hear the results at the beginning and end of video. Also gives you before and after
zoutlawss is offline   Reply With Quote
Old 09-01-2018, 07:50 PM   #12
TJay74
When I had my 1LE I did the secondary cat deletes 1st, it sounded great and the car picked up some power. Then I put the ARH catless headers with the full system on it where it connects right before the NPP muffler, loud is an understatement for sure.
Personally I like the raspier sounding exhaust in the form of an exotic tone. I dont like the deep rumble like an old chevy pick up with Flowmasters on it sound. That is just my preference, others opinions may vary.
Old 09-05-2018, 11:35 AM   #13
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
sounds like you are describing the Hooker Blackheart exhaust. Not a low price option though!
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 09-05-2018, 01:19 PM   #14
KingLT1
KingLT1's Avatar
Not if you keep the secondary cats.
