Old 08-29-2018, 10:29 PM   #1
aBee150
@NHTFALL
aBee150's Avatar
Drives: 2018 Camaro 1SS 1LE
My Headliner Fix
As many of you are aware, the headliner has a tendency to show the foam and appear to be peeling.
After looking through the forum discussions someone gave the idea of using a U-Channel strip similar to that sold for car door edges. After sourcing the trim, I knew it wouldn't work because it was too small and hard to fit.
What I ended up doing is buying this.
Aside from the texture (a little bumpy) it ended up working pretty great! It has a metal "U" inside the wire so it opens and snaps closed around the headliner edge. Due to the shape of the headliner, I left an inch off both edges.
The first image shows how the original headliner looks (the foam)
The third to last photo shows after. I know it looks like there is still white but that's just the reflection of the rubber. It looks a lot better in person. If I am being perfectly honest, if I were to do it again, I would choose a trim that is more opaque. Lets see how it holds up with time.
aBee150 is offline   Reply With Quote
Old 09-11-2018, 12:15 AM   #2
aBee150
@NHTFALL
aBee150's Avatar
Update
I bought a different trim which ended up working a lot better! It almost looks stock!
Here is the link on amazon.
and some pics:
The white foam is no longer visible at all!
Old 09-14-2018, 07:00 AM   #3
soldes
Drives: car
After a year it finally happened. The white carrier material is showing. Your second solution looks nice. Got to have a look at that as the dealer will probably be useless..
Nick
soldes is offline   Reply With Quote
Old 09-16-2018, 08:25 PM   #4
aBee150
@NHTFALL
aBee150's Avatar
Nick
Thank you. If you decide to do it, let me know if you have any questions. I opted to not go to the dealer for it because I've read it comes back.
Old 01-05-2019, 12:53 PM   #5
7speed
Drives: 21 SS
Im about to have mine replaced next week at dealer.
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 06-20-2019, 03:05 PM   #6
Makatich
Drives: 2017 Camaro 1LE
TSB #17-NA-298: Headliner Sag - (Jan 16, 2019). Dealer will replace the windshield and headliner for free due to “mishandling” at the factory. Basically the line workers did not install the headliner correctly. You will need to give them this TSB to lookup to have it covered under warranty.
Makatich is offline   Reply With Quote
Old 06-20-2019, 03:57 PM   #7
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
Nice to know there's now a service bulliten for the headliner issue. Last week I finally did what the OP did here in this thread, and am debating weather to go the dealer or not now
HCI2000SS is offline   Reply With Quote
Old 06-21-2019, 01:09 AM   #8
aBee150
@NHTFALL
aBee150's Avatar
I've heard of people going to the dealer to get it fixed only for it to show again or lead to other issues, and while they are all covered by warranty it seems like a huge hassle to me. Anytime I take my car to the dealer i regret it lol.
Old 06-21-2019, 08:29 AM   #9
kraut1971
BITCHN Camaro
kraut1971's Avatar
Drives: SOLD! Back in the looking zone...
Follow
BITCHN
kraut1971 is offline   Reply With Quote
Old 06-21-2019, 09:52 AM   #10
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
and some pics:
Does this trim from Amazon have adhesive on one side to attach to the windshield?
2016 Hyper Blue 2SS, A8, NPP, MRC
V8Addict is offline   Reply With Quote
Old 06-22-2019, 01:15 AM   #11
aBee150
@NHTFALL
aBee150's Avatar
No, it's just a pressure fit. As of today since I've made this post, it hasn't fell off and has remained exactly how I installed it
Old 06-22-2019, 10:05 AM   #12
HCI2000SS
HCI2000SS's Avatar
IMO the best part about this rubber trim mod, is how it looks from the inside. No longer do you see the crappy cut of the headliner.... especially where it dips down on the passenger side. From the outside you no longer see the white foam of the headliner, but instead you see the rubber trim itself. Obviously it would be best to see nothing at all, but for the time and money (plus not having to deal with the dealership) it's a great little option
headliner, headliner fix, rubber trim
