Old 08-29-2018, 11:41 AM   #1
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
DIY transmission fluid change
Who has done a tranny fluid change themselves? I want to change to synthetic after 77k kms.
Wonder where the fill hole is? Is it the hex bolt located driver side up top or is the torx bolt on the passenger side?
Thanks to anyone that can help!
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq
ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator
Adp2017 is offline   Reply With Quote
Old 08-29-2018, 03:10 PM   #2
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
If you don't have a fluid fill pan adapter to use the fluid check plug, you will have to use the fill tube method. Be sure to clean around the fill tube very well before pulling it out. A lot of crap accumulates around that area, and it will fall inside the hole. Here is the location of the plug.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 08-30-2018, 10:07 AM   #3
Adp2017
Adp2017's Avatar
Thanks cooper I managed to figure it using the fill tube method.
331 rwhp , 350 rwtq
