Old 08-27-2018, 10:01 PM   #1
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
Blower inlet diameter??
Does anyone know the blower snout inlet diameter? The diameter of the blower where the throttle body connects? Was contemplating getting a ZR1 throttle body that's 95mm. But if the blower inlet is smaller it won't help much.
Thanks..
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / /
1LE Red Dragon is offline   Reply With Quote
Old 08-27-2018, 10:09 PM   #2
waterman
waterman's Avatar
Drives: Grandad's C2 L89
TB is 87mm. I believe that you would need a spacer/adapter and tune to go larger.
2018 ZL1 1LE sw/PDR
Old 08-27-2018, 10:18 PM   #3
1LE Red Dragon
Train Driver
Yep. I know stock TB is 87mm. But I'm not sure the snout inlet is 87mm. And I was looking at the TB and adapter to fit it. Usually opening up the inlet before the blower helps power. And atune would be required with bigger TB.
2018 Camaro ZL1LE
