Old 08-26-2018, 09:44 PM   #1
JRS
JRS's Avatar
Drives: 16 camaro M6/ 18 ZL1 camaro A10
shifting in manual mode without moving the shifter into manual mode
I don't know if this has been written about before but did anyone know that on the A10 if you have it automatic mode you can manual shift with the paddle shifters and it will put it into manual mode then will revert back to automatic mode once you stop.
I just happen to hit the paddle shifter and it reverted to manual mode.
Sorry if this was common knowledge.
JRS is offline   Reply With Quote
Old 08-26-2018, 09:46 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
all autos were like this since 11'.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 08-26-2018, 09:48 PM   #3
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Lol?
Old 08-26-2018, 09:52 PM   #4
JRS
JRS's Avatar
I thought it would only work in manual mode, haven't really driven newer automatic until now.
Old 08-27-2018, 01:49 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
From the manual: Chevrolet Camaro Owner Manual (GMNA-Localizing-U.S./Canada/Mexico9804281)- 2017 - crc - 4/25/16 Driving and Operating 229
"Temporary Tap Shift Mode allows brief entry into Tap Shift Mode while in D (Drive). Tapping either the upshift or downshift control will place the transmission in Tap Shift Mode. Exit Tap Shift Mode by holding the upshift control for two seconds. The system will return to automatic shifting after seven seconds of driving at a steady speed, or when the vehicle comes to a stop.
This may be used for sport driving or when climbing or descending hills, to stay in gear longer, or to downshift for more power or engine braking. The transmission will only allow you to shift into gears appropriate for the vehicle speed and engine revolutions per minute (rpm). The transmission will not automatically shift to the next higher gear if the engine rpm is too high. If hifting is prevented for any reason, the message SHIFT DENIED will appear in the DIC, indicating that the transmission has not shifted gears.
While in the Tap Shift Mode, the transmission will not automatically downshift on hard acceleration. When accelerating the vehicle from a stop in snowy and icy conditions, you may want to shift into 2 (Second) gear. A higher gear ratio allows you to gain more traction on slippery surfaces."
Old 08-27-2018, 12:02 PM   #6
kttxz06
kttxz06's Avatar
Drives: '18 Zl1. '18 GT350.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
kttxz06 is offline   Reply With Quote
