Old 08-25-2018, 10:11 AM   #1
Chris Edwards
Drives: 2017 ZL1
ZL1 Alignment Issue Fix?
Who has had repeated alignment issues (crooked steering wheel and skewed toe) and what did you do to fix it?
BMR stuff?
More torque on eccentrics?
1LE cradle bushings?
All of the above?
Chris Edwards is offline   Reply With Quote
Old 08-25-2018, 01:52 PM   #2
WyGuy
Drives: 2017 ZL1 M6
Competent alignment guy? I haven’t had any issues...
WyGuy is offline   Reply With Quote
Old 08-26-2018, 10:19 AM   #3
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
I aligned mine myself (on our Hunter Hawkeye machine) a few months after I got it new, and haven’t had any issues. Which adjustment exactly is moving? I could see a rear eccentric causing a thrust angle issue, which would cause a crooked steering wheel. That should be pretty easy to figure out by marking the eccentrics.
BMWM.D. is offline   Reply With Quote
Old 08-26-2018, 12:21 PM   #4
ICTsccaCamaro
Drives: 2018 ZL1 1LE
Alignment issues are typically fixed with a alignment…
ICTsccaCamaro is offline   Reply With Quote
