![]() Drives: 2018 ZL1 NGM Join Date: Jan 2018
Clear Bra Self Apply??
I’ve applied racing stripes and decals on vehicles but wasn’t sure just how difficult it would be to buy a precut kit (like 3M or Xpel) and apply myself. I’m going to do the front bumper and “bikini cut” hood. Seems like I will save a bunch doing it myself (upwards of $500).
Has anyone here had any success at doing it themselves?? Thanks!!! Lou |
its a cross between doing window tint and vinyl wrap. it is very thick and it will not conform like vinyl wrap does. I would suggest having a second person help you, and a couple bottles of soapy/water and I like the felt flexible squeegees for the front bumper. Clay bar the areas you want to do as well as a 40-50% water/isopropel alcohol wipe down.
![]() Drives: Trans am Join Date: Jan 2015
Where are you buying the material? When I looked the install was almost free compared to buying the material myself
#4 | |
![]() Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
You will need a steamer. Steamer is excellent not only for (after a full clean) getting in the edge areas, and removing wax on those edges. On the front bumper, once you get the "anchor points" down... you'll see the need to stretch material to conform. That is where a blast from the steamer comes in. (Similar to doing the door cups where you'd anchor left and right, then steam the center quick so it stretches). The Xpel patterns are pretty darn good (better than the Suntek patterns but, my guy gets the Xpel patterns and uses the Suntek)
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
#5 | |
https://www.ebay.com/itm/Chevrolet-C...4AAOSwgv5ZOknR So far, the two quotes I got here locally are between $850 - $950 at the XPEL shops. I live just north of Houston. |
#6 | |
#7 | |
![]() Drives: 2024 ZL1 M6, 1978 Beechcraft Baron Join Date: Jun 2018
I got Xpel done on my front bumper, rockers up to the crease, and rear bumper behind the rear tires done for $775 in Dallas. The install was first rate and took about 3-4 hours. |
#8 |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
I’ve been told the front bumper is not an easy job on these cars. In my opinion, it’ll take some experience to make it turn out nice. Wouldn’t be worth saving a few hundred bucks; at least to me.
#9 |
![]() Drives: 2017 Camaro Zl1 Join Date: Nov 2016
The front bumper on the ZL1 is one of the most challenging jobs out there. I wasted a expensive pattern trying it myself. I did all the flat areas will no problem but that bumper is a .....
#10 |
![]() Drives: 2017 ZL1 Join Date: Jun 2012
+1. If you haven't ever done this, I wouldn't bother trying a big complicated piece like a ZL1 bumper. My bumper was a hair over $500 installed. Much more than that is a ripoff. The material isn't cheap enough that you can really do it yourself and save money. I leave ppf to the pros, because they obviously get it at a cost we can't get, so they can afford to mess up. You mess up at all and you're screwed. Plus, I wouldn't go with anything other than Suntek or Xpel as a 2nd choice.
#11 |
![]() Drives: 2018 Camaro ZL1 Garnet Red Join Date: Jul 2018
I could see how one may attempt the install on their own if their car started off perfect, but most aren't.
Even from the dealer, my installer spent a day and a half with the clay bar, polishing, and fixing areas prior to the install. For that reason, the install cost was well worth it in my eyes. |
#12 |
![]() Drives: ZL1 A10 Join Date: Dec 2017
After watching my installer put on just the front splitter piece I can't imagine how tricky the bumper was. There is no way I would try this on my car. Plus if you have it done by an authorized installer it is warrantied.
My rides:
2017 Camaro ZL1 A10 2015 Jeep Grand Cherokee Diesel 2012 Audi S4 1992 Porsche America Roadster 1990 BMW 325Ic |
#13 |
![]() Drives: 2018 Camaro ZL1 met-black/manual Join Date: Jul 2018
I had the same plan as you and installed the bikini cut hood (3M) myself with a bit of effort but it came out really nice. My family could not even tell it was on.
So, I tried the bumper and basically destroyed the film. I think you would need 3 people to do that front bumper. Very complicated to hold and apply at same time. . I would have it done professionally. One thing is I did have a couple of bubbles, but if you leave the car in the hot sun for a couple days, they do disappear, so don't worry if after either you or the pro end up with some small bubbles. What I was told is the film does have some microscopic holes to relieve this. I believe it. |
#14 |
Thank you Al Oppenheiser!
In increasing degrees of difficuly...
1. 2 bucket wash a car. 2. Applying a paint sealant. 3. Using a foam cannon to get a good shaving cream. 4. Changing an air filter. 5. Changing oil. 6. Polishing paint. 7. Beating KTTXZ06 in a roll race. 8. Beating Mr. Wyndam on the track. 9. Conving my wife to let me build another garage on the house so I can get more cars. 10. Winning the lottery. 11. ... 12.... ... ... 30. Winning an argument on the internet. ... ... . . . . . . 87 ... Sucessfully installing PPF perfectly on the front bumper of a 6th gen ZL1. |
