Old 08-19-2018, 08:50 PM   #1
Ebbsnflows
Drives: 2018 Camaro ZL1-1LE
How much weight does 2.9L Whipple add?
For those that have installed a 2.9L Whipple, what is the total net-weight gain? I've read that that the shipping weight is approximately 150lbs (give or take a few lbs for box/packing material).
I'm looking for: Weight of Whipple/accessories (-) weight of stock intake (and anything else that is removed). Would 130 lbs be a reasonable guesstimate?
Anyone notice any change in handling characteristics? I would think 130 lbs over the front wheels would be noticeable during cornering/braking?
2018 Camaro ZL1/1LE
Ebbsnflows is offline   Reply With Quote
Old 08-20-2018, 07:04 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Once you add coolant you’re probably close to ZL1 weight.
Old 08-21-2018, 05:56 AM   #3
L78toLT1
L78toLT1's Avatar
I've got a Maggie, which I'm sure weighs about the same as a Whipple. The extra weight is definitely noticeable on my SS, particularly with the MRC in Tour mode. It's not as bad in Sport, or Track. The stiffer springs & slightly lower ride height on the 1 LE should help to mitigate the negative affects on handling.
Baby Blue
Old 08-21-2018, 08:20 AM   #4
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
I haven't weighed my car since adding the Whipple, but it is most definitely noticeable. I've gone to stiffer springs that offset a lot of that in transitions, but it's probably 150 pounds with the coolant.
It's still worth it
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq
Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers
Chris V is offline   Reply With Quote
Old 08-21-2018, 10:38 AM   #5
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Per Fed-Ex the shipping weight of my whipple was 149 lbs, plus 2 gal of coolant which is around 16 lbs. Although you probably remove 16 lbs worth of stock parts. So I would agree with Chris V that the whipple probably adds 150 lbs.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 08-23-2018, 03:36 PM   #6
Ebbsnflows
Thanks guys - I Appreciate the honest and candid responses.
2018 Camaro ZL1/1LE
Old 08-24-2018, 08:56 PM   #7
TJay74
I am pretty sure the coolant isnt additional to the factory coolant capacity, it is just for replacing the original coolant when you break the system open.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 08-24-2018, 09:53 PM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
PD blowers have their own coolant system for the intercooler. They are liquid cooled instead of air like a procharger.
Old 08-25-2018, 06:22 AM   #9
laynlo15
Drives: 2022 Lt1 A10
My Maggie added about 60 lbs on the front, remember there was you stock intake and other stuff that comes off before you add the SC. Don't know about Whipple weight so you should probably choose a Maggie since it will probably be a little lighter too.
Old 09-07-2018, 12:38 PM   #10
80sMetalDude
80sMetalDude's Avatar
Drives: .
I was going to say something similar I think the unit was around 85 lbs... far from 150.
80sMetalDude is offline   Reply With Quote
Old 09-12-2018, 12:09 PM   #11
cbr1100xx
Drives: '14 Jetta 1.8, '19 1SS
I had Whipple S2 installed on my '15 Mustang GT PP. It added about 150lbs. My car was lowered and you could tell a little bit with the handling the added weight but not that much. The added torque was noticeable though since the S550 lacks that down low IMO.
The boost made the car wicked fast. Traction from a dig was very difficult as I'm guessing it would be for the Camaro too.
If I go the Camaro route, I'd go 1SS 1LE and wouldn't boost it. I just couldn't use the power most of the time.
cbr1100xx is offline   Reply With Quote
