08-19-2018, 11:02 AM | #1 |
BAMF SS
Finally made it to the track for the first time with my car
I thought the drag strip was going to be rained out yesterday. A few days ago it was 90% chance of rain. Yesterday morning, when it said 60% chance, that was close enough for me to risk it. The car was on a very safe tune. And I had no way of dialing in the 1-2 shift or 2-3 shift before, because trying to hook at WOT with the 5c converter and 3.73s on street tires is not happening. And I was only at ~25-26* of timing.
Ended up giving it a lot more timing and fought with torque reduction/tm Ended up going 11.16 @ 123.59 with a 1.52 60'. I picked up almost 27 mph out the back half, and was hitting over 50 lbs/min on the MAF. So it makes good power, imo. Having issues with the throttle body closing, and the torque converter isnt locking until 4th gear. Shift times still need adjusted and shortened. I didnt have the wideband on the car, so I didnt want to give it any more timing than I already had, without verifying AFR. Ricer excuses: This was at 3500 DA This was at full full weight. Back seats and passenger seats and such are still in the car https://youtu.be/PFw_h2rwEXk
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
08-19-2018, 11:50 AM | #2 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Not bad at all for first time out with it.
Seems the converter not locking until 4th is par for the course. Hopefully someone can figure it out |
08-19-2018, 12:14 PM | #3 | |
BAMF SS
I thought I read somewhere that someone managed to get it to lock on the top of 2nd/bottom of 3rd. If I can get that sorted out, and not have the throttle.body close to 30% in first gear, I think I might be in what I like to call "Snowblind and Ultrazls1 territory."
08-19-2018, 12:25 PM | #4 |
Lol you will be for sure
11.1 in that DA is pretty good and leaving almost another tenth on the table with front and rear seats. And plenty of tuning to do still. 10.7 or better this fall IMO I’ve done a couple more things but still no converter. I should have enough to squeeze into the 10.7s but likely a little behind you and snowblind as I’m still sticking with the stock converter for now |
08-21-2018, 10:46 AM | #5 |
good run!
2016 NFG 1SS A8
08-21-2018, 12:35 PM | #6 |
Drives: 2016 2SS Join Date: Jul 2016
With that converter and gear it won't lock till 4th. You may get the top of 3rd but I doubt it. The stock converter doesn't lock till 3rd. Now you have exponential slip to deal with. Nothing can be done about that. I did get my 4C to lock up at the top of second with a ton of work but that was on the 2.77's and a 28" tire.
You can keep the TB blade open with proper tuning. That shouldn't be an issue at all. Dig into the trans/VT/ET. More timing won't help. You are bout optimized. Possibly 1* more but then you are into diminishing returns. The 60ft probably won't improve much. You are most likely shifting before the 60ft out of 1st with the stall slip and gearing. So you won't get a true assessment of the 60ft as you would with a higher gear and making it out in 1st. I would take your 330ft as a better comparison to the rest now. Good runs for the weight and conditions though. Best I did with ported heads in those conditions was 10.90's with the stock gears at full weight. 3,840lbs. |
08-21-2018, 01:04 PM | #7 | |
BAMF SS
I'm actually hoping to get a good amount out of the 60', or maybe I'm being optimistic. The throttle body was closing all the way to 30% for first gear and my shift times were in the ~450 ms range. Just need more TNT time to get everything ironed out I hope. Thanks for all the input Hopefully going back on friday for more fun. ADO said the DA for this past run was 4500. Dragtimes says 2800. Either way, this Friday should be a lot better, and I can at least break out a 10 second timeslip
08-21-2018, 01:08 PM | #8 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Solid passes Dan
You'll get that puppy dialed in, it takes some trial and error with the gear change. It's good to see that their should be at least 4-5 new members in the Cam6 bolt-on 10 Second Lounge this fall.....and don't let Ultra try to play that Underdog card, he's swinging for the fences too even though he acts like he's not.
08-21-2018, 01:13 PM | #9 | |
BAMF SS
08-21-2018, 01:25 PM | #10 | |
These are the things people never dig into. Good example are the top dog blower cars that leave in 2nd and go from 1.43 60fts to 1.37 60fts. The car simply can't react fast enough the way this trans works to get it right. You have to command such a low mph to execute the shift that the car really isn't seeing power for up to 1K rpm. |
08-21-2018, 01:29 PM | #11 | |
All the fast cars come from Maryland and NC. Last edited by PRAY; 08-21-2018 at 02:01 PM. |
08-21-2018, 01:50 PM | #12 | ||
BAMF SS
and if all the fast cars come from Maryland to NC, then why are you going back to Maryland in the fall.... you are doing it backwards
08-21-2018, 02:00 PM | #13 | |
I am heading up to Maryland cuz the track there is only 1,317ft long and it has a 17ft drop from starting line to finish line in the right lane and an 18ft drop in the left lane. Seeing a trend here? And you learned me something. Didn't know about the Commonwealth thing. If you truly want the 3.73 gear to work then put the car on a 26" tire and launch it in 2nd. That will get you through the 60ft in one gear and still allow you to utilize more of 6th gear. You can get quite a bit more time in the 1:1 gear with the 26" tire. Now I am giving away all the secrets. |
08-21-2018, 02:11 PM | #14 | |
BAMF SS
